Toggle Switch Wiring?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=42506
Printed Date: April 24, 2024 at 10:47 PM
Topic: Toggle Switch Wiring?
Posted By: NinePM
Subject: Toggle Switch Wiring?
Date Posted: November 08, 2004 at 12:08 PM
hi to all! i ran in a little problem, and can't find anywhere how to wire this little kid. I know it's written on the switch how to wire, but this is the first time i'll install it so need little wider explanation. This is illuminated toggle switch, and i want to make on/off one of my lighting accesories in my car, so what would be a wiring diagram? sorry for a dunno question, but i hope to get answer
Posted By: NinePM
Date Posted: November 08, 2004 at 3:23 PM
so i kinda figured out that possibly + (power) wire and - (ground) wires are just for illuminating the switch, but how the load switch works, if i just have one pin for load? i know i probably making it very difficult for myself...but can't figure out how.... . i'm used to the two pin switches which i installed lots of them at home, so basically you just cut the wire and connect both ends to the switch, so, when you want light off switch just cuts the power in itself....but with these kids, i don't know, something strange...
Posted By: Teken
Date Posted: November 08, 2004 at 3:45 PM
The middle pin will have power applied as well. This will turn on the light within, if the light is not incandecent, and is a LED, you will need to add in a series resistor aprox. 300-470 ohms will do.
This depends on the max current the LED can handle, most are rated at 20 mA, others such as blue LEDs are at the upper range of 40-45 mA.
The other two posts power and ground, are simply connected to a fused +12 volts, and the other is to chassis ground.
------------- Knowledge is power. But only if you apply that knowledge in a positive way, which promotes positive results in others.
EVIL Teken . . .
Posted By: overworked
Date Posted: November 09, 2004 at 7:56 AM
OKay it is relatively easy to wire this, Earth is earth and is required for the switch (+) pin is the first part of your "load" power in wich supplies power to the switch and the third pin is you other part of the load or Power out sorry Teken but no resistor is required because it is built in, this is quite a popular switch in Australia. I know I'm a newbie but if I had a dollar for everyone of these I've installed!!! -------------
Posted By: NinePM
Date Posted: November 09, 2004 at 10:40 PM
sorry my language understanding is kind of poor, so i better understand pictures, i thought a long way how to connect, and suddenly i came up with idea like this : Legend: RED - power wire positive BLACK - negative, ground YELLOW - is my light is that the right thing to do, cause i can't think of any other, i hope this is right, just want to make sure before i connect. thanks
Posted By: Asmodeus
Date Posted: November 09, 2004 at 10:59 PM
You are correct. Hook it up just like you have drawn above and you have it ------------- Making the World A Louder Place
Posted By: switch_hitter
Date Posted: November 09, 2004 at 11:25 PM
ok maybe im not understanding correctly..but this is how i have always installed these switches. Power-12v Ground- Ground ACC-(the + wire of the accessorie that you are installing) when you hit the switch you complete the circuit and turn the accessorie on.. ------------- 2 Memphis HPO 12s
1 Memphis 1000D
2 Memphis 8s
1 Memphis MC200
4 Memphis 3way 6 1/2s
1 Memphis MC3004
4 Memphis Tweeters
1 Memphis 3-way electronic crossover
2 Memphis 5 1/4
2 Memphis 4s
Posted By: Asmodeus
Date Posted: November 09, 2004 at 11:55 PM
Switch...That is exactaly right....And that is what NinePM has illustrated above.... ------------- Making the World A Louder Place
Posted By: NinePM
Date Posted: November 10, 2004 at 6:36 AM
finally! congrats to me, and thanks for replies later
Date Posted: November 10, 2004 at 8:07 AM
thats what i thought, cool...just clarifying..
1 Memphis 1000D
2 Memphis 8s
1 Memphis MC200
1 Memphis MC3004
4 Memphis Tweeters
2 Memphis 5 1/4
2 Memphis 4s
