TPS switch
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=61246
Printed Date: May 28, 2024 at 8:04 PM
Topic: TPS switch
Posted By: galantin
Subject: TPS switch
Date Posted: August 12, 2005 at 11:05 PM
im trying to hook-up a relay to power up a water injection pump on my car. i need a throttle switch like a nitrous setup but instead of wide open throttle, i need one that closes at part throttle. my TPS sensor puts out about .5 volts closed and about 4.9 at WOT, i need it to power up a relay at about 1.0 to 1.5 volts and stay on all the way to WOT. any ideas?
Posted By: boulderguy
Date Posted: August 13, 2005 at 2:25 AM
Didn't you get the memo about your TPS sensor? You need to use a different cover sheet with those from now on. I'll get you another copy of the memo.
Posted By: galantin
Date Posted: August 13, 2005 at 4:29 PM
huh?
Posted By: Francious70
Date Posted: August 16, 2005 at 10:40 AM
Mmm hey galantin. Whatsup?? Mmm yea, did you get that memo this morning about using the new cover on the TPS report??
"Yes I got the memo"
WEll you didn't use the new cover sheet for the TPS report. Did you get that memo?? I'll make sure you get it. Mmm bye.
Oh, by. the. way. I'm gonna have to ask you to come on in on Saturday. Yea. And on Sunday too. Greeeeeeat.
Bill Lumberg
Posted By: galantin
Date Posted: August 20, 2005 at 7:25 PM
riiiiiight, im gonna go ahead and disagree with you on that... how much time do you spend on the tps reports?? no but foreal can anyone help with this?
Posted By: dk77
Date Posted: August 24, 2005 at 5:08 PM
It sounds like you want to run a single-stage setup, with no modulation on your water injection. Most injection kits use a digital controller that operates off of mass-air flow or TPS. This is for a modulated application,though. Is there a relay (adjustable perhaps?) that will activate at 1.5 volts? 1.5 volts is on the low end of your TPS voltage spec, so you may just want to flip a switch to activate the injection.
Posted By: galantin
Date Posted: August 24, 2005 at 10:25 PM
well if i had a switch i would have to turn it on and off everytime i hit the gas, so that wouldnt work, i cant have it on at closed or very light throttle because it would cause a missfire. the relay sounds like a good idea but where can i find one like that.
Posted By: geepherder
Date Posted: August 26, 2005 at 7:43 PM
What you can do is connect a potentiometer in series with the coil of your relay. Keep adjusting it until the relay activates where you need it to. Then, take a resistance reading of the pot where it's set, and replace it with a resistor of that same value.
------------- My ex once told me I have a perfect face for radio.
Posted By: galantin
Date Posted: August 26, 2005 at 8:17 PM
that also is a good idea but still i would need a relay that could activate at a very low voltage, the only relays i know about(and can get) are the 12 volt kind. i found an output on the tps (4 wire) that is grounded when the throttle is shut (closed throttle switch)so i might just wire a relay to that and connect the pump to the normally closed 87a terminal so that the pump only activates above closed throttle.
