95 nissan maxima remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=66684
Printed Date: May 15, 2024 at 8:34 PM
Topic: 95 nissan maxima remote start
Posted By: elvis233
Subject: 95 nissan maxima remote start
Date Posted: November 20, 2005 at 6:49 PM
just installed a remote start into my 95 nissan maxima but it's have trouble starting engine.. if i start it by key it starts right up, if i use the remote start the engine sound like it's almost going start but it doesnt or sometimes it will but never when cold.. there is a blinking security lite from the factory could it be the factory security system causing this problem
how do i fix this problem.. do i need a bypass module
Posted By: Teamrf
Date Posted: November 20, 2005 at 8:05 PM
Try this.....put the key in the ignition to the start position...and try remote starting it....post what happens here.
------------- ~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Posted By: KaMLuNg
Date Posted: November 20, 2005 at 10:10 PM
what kind of remote start system is it?? is it tachless??? or is it a timed start??? if it is timed and the engine is barely starting then the crank isn't timed long enough...
Posted By: chriswallace187
Date Posted: November 21, 2005 at 1:22 AM
'95 Maximas do not require a bypass module, so that's not a worry. Did you hook up the second starter wire? I've never been given a completely satisfactory explanation for the second starter wire on Nissans, but I understand it has something to do with cold starting, which may be your problem.
------------- C Renner's Auto Electronix
