2002 Durango remote start, difficult?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=6898
Printed Date: June 09, 2024 at 9:13 AM
Topic: 2002 Durango remote start, difficult?
Posted By: HotRod53F100
Subject: 2002 Durango remote start, difficult?
Date Posted: December 19, 2002 at 7:17 PM
Just picked up this 2002 Durango and I'm concidering a remote starter. This thing has a factory anti-theft system, how difficult will it be to install a remote starter? Thanks!
HotRod
Posted By: jrilla
Date Posted: December 19, 2002 at 9:31 PM
With no experience, give yourself a day and you should be able to get it done. It is not too complicated, but it does take time your first time.  Get a good wire diagram and prep your wires before hand and it should go rather smoothly.  You will need a tansponder bypass kit and for your door locks you will need two relays and two resistors(your wire diagram will give specific numbers) If you have a factory alarm as well you will need a relay and a resistor to disarm it.  Here is a wire diagram:  Ask any more questions you have.  The transponder bypass is actually very easy, but it takes time the first time like I said.
Dodge
Durango
2000-2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
YELLOW
IGNITION SWITCH HARNESS
Ignition  #1:
DK. BLUE
Ignition #2:
GREEN/ RED
Ignition  #3:
N/A
Accessory:
BLACK/ /ORANGE & GREEN (2 WIRES)
IGNITION SWITCH HARNESS (BLOWER MOTOR)
Brake  Light:
WHITE/ TAN
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
BLACK/ GRAY
AT IGNITION COIL OR AT PCM *
Parking Lights:
BLACK / YELLOW
AT HEADLIGHT SWITCH
Headlights:
LT. GREEN
AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
LT. GREEN/ ORANGE (-)
16 PIN CONN. BELOW DR. FUSE BLOCK
OEM Alarm  Arm:
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * Ignition Coil Is Located On Passenger Front Of Engine. Powertrain Control Module (PCM) Is Located On Passenger Rear Of Engine Compartment In Front Of Washer Fluid Reservior.
Dodge
Durango
2000-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED & PINK/BLACK
Starter  Kill:
YELLOW
Ignition  +12 Volts:
DK. BLUE
Dome  Lights/Superv:
YELLOW (-)
AT COURTESY LIGHT UNDER DASH
OEM Horn:
BLACK/ RED (-)
STEERING COLUMN HARNESS
Power  Lock:
GREEN / WHITE
AT CENTRAL TIMER MODULE IN DRIVER'S KICK PANEL ***
Power  Unlock:
GREEN / WHITE
Trunk  Release:
N/A
Alarm  Input Wire:
YELLOW (-)
Notes:
*** Single Wire Lock System, A Negative Trigger Through A 820 Ohm Resistor Will Lock Doors. A Negative Trigger Through A 330 Ohm Resistor Will Unlock Doors. **** Single Wire System, A Negative Trigger Through A 644 Ohm Resistor Will Arm And Lock The Doors. A Negative Trigger Through A 1565 Ohm Resistor Will Disarm The Alarm And A Second Pulse (Double) Will Unlock The Doors.
J Rilla
Owner/Installer
Posted By: securinu
Date Posted: December 20, 2002 at 2:23 PM
i have an 02 as well and have an m-10 in it pretty simple install let me know if i can help when your ready
