Looking for a wire diagram and wire location for a pro-start 2300 remote starter for a 1992 pont. grand-prix with a 3.1 and power door locks
daddy o
For the 1992 GP:
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|red |+ |ignition harness |
| STARTER|yellow |+ |ignition harness |
| IGNITION|pink |+ |ignition harness |
| SECOND IGNITION|dark blue/white |+ |ignition harness |
| ACCESSORY|orange |+ |ignition harness |
| SECOND ACCESSORY|PURPLE / white |+ |ignition harness |
| POWER LOCK|lt. blue |+ |either kick |
| POWER UNLOCK|black |+ |either kick |
| PARKING LIGHTS +|brown | |headlight switch *1 |
| HEADLIGHTS|yellow |+ |headlight switch |
| DOOR TRIGGER|white |- |headlight switch *1 |
| DOME SUPERVISION|use door trigger | | |
|TRNK/HTCH RELEASE|black |+ |release switch |
| TACHOMETER|pur/wht or white | |igniton coil *2 |
| SPEED SENSE|green |4 |PCM *3 |
| BRAKE WIRE|white or lt. blue |+ |brake switch |
| HORN TRIGGER|black |- |steering column |
| WIPERS|purple |+ |wiper switch |
| LF WINDOW UP/DN|dk. blu - brown |A |drivers door motor |
| RF WINDOW UP/DN|dk. blu/wht - tan |A |in drivers door or dkp |
| LR WINDOW UP/DN|dk. grn - purple |A |in drivers door or dkp |
| RR WINDOW UP/DN|lt. grn - pur/wht |A |in drivers door or dkp |
Notes:
*1 Also found low in the drivers kick panel. *2 Also found at the instrument cluster as white. *3 The PCM is located in the passenger kick panel. The VSS wire is also found at the instrument cluster.
