1990 240sx 5 spd cruise ctrl relocation
Forum Name: Cruise Controls
Forum Discription: Cruise Control Settings, Tach Signal, VSS PPM(Vehicle Speed Signal Pulses Per Mile), Vacuum, Brake, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=101424
Printed Date: May 09, 2026 at 12:38 PM
Topic: 1990 240sx 5 spd cruise ctrl relocation
Posted By: lbrowne
Subject: 1990 240sx 5 spd cruise ctrl relocation
Date Posted: January 21, 2008 at 8:13 AM
My cruise stopped working through the steering wheel controls a little while ago. The cruise system turns on no problem, as indicated by the grear dash button light.
I've taken steering wheel button controls from another 240sx, and mounted it in my center console. It has a Red, Yellow, and Blue wire. I have the yellow wire spliced into the GREEN / WHITE harness so the horn can operate - I believe the yellow wire is for the "cancel" button.
The other two wires are GREEN/ Orange and GREEN/ YELLOW. Seems easy enough but when I connected it up it didn't work, I swapped the red and blue wires and it still didn't go. Are these connections hot swappable? (change them while car still running  and they'll work?)
I change cars too often to put one here.
Posted By: lbrowne
Date Posted: January 29, 2008 at 12:25 AM
not alot of action in this section huh? lol
Posted By: zziggy
Date Posted: February 01, 2008 at 10:18 AM
yellow green at I/P connector behind glove box near door pillar of Pass side.
To gain access squeeze sides of glove box and lower out of the way.
Your Yellow Green is probably the same wire.
Courtesy of an old ARA who is now an SCS distributer.
Posted By: lbrowne
Date Posted: February 01, 2008 at 4:39 PM
huh? ok, so which wire connects to the GREEN/ YELLOW? The red one or the blue one?
The wires coming from the button are red, blue, yellow. I'm trying to connect these to the wires in the steering column that are the colors above..
