adding cruise control on 2008.5 titan
Forum Name: Cruise Controls
Forum Discription: Cruise Control Settings, Tach Signal, VSS PPM(Vehicle Speed Signal Pulses Per Mile), Vacuum, Brake, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=102302
Printed Date: May 09, 2026 at 5:39 AM
Topic: adding cruise control on 2008.5 titan
Posted By: boost_junkie21
Subject: adding cruise control on 2008.5 titan
Date Posted: February 18, 2008 at 3:06 AM
I recently bought a 2008.5 nissan titan xe. It didn't come with cruise but I'm wanting to add it. I was told that it MAY be possible that the dash harness may contain the connector for the factory cruise switch. If this is true, does anyone know if the programming is on the ecu for cruise. The titans have a "drive by wire" throttle so I don't think any aftermarket cruise control units will work on my truck.
Posted By: Mark Mizenko
Date Posted: February 18, 2008 at 3:46 PM
You can try Trilogix, they have cruise for vehilce with "drive by wire". I k ow they do some Nissans, I'm not sure about your Titan, sorry.
Posted By: manahawkinrob
Date Posted: February 19, 2008 at 11:57 AM
I bet the whole cruise program is already in the onboard computer. I recently bought an 08 Aveo without cruise, and bought the switch for 15 bucks and connected 2 wires and bingo, I had cruise control. I bet it is all there.
Date Posted: February 21, 2008 at 6:36 PM
I'm hoping it is too. I'm almost certain it is but I don't wanna take the chance and it not be there after I bought all the switches and wiring ($210) and it not work.
