05 chevrolet silverado, cruise wiring
Forum Name: Cruise Controls
Forum Discription: Cruise Control Settings, Tach Signal, VSS PPM(Vehicle Speed Signal Pulses Per Mile), Vacuum, Brake, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=102772
Printed Date: May 09, 2026 at 12:53 AM
Topic: 05 chevrolet silverado, cruise wiring
Posted By: larkster
Subject: 05 chevrolet silverado, cruise wiring
Date Posted: March 04, 2008 at 10:41 AM
anybody seen a truck with no cruise control  wiring at either side of the main connector.  do you know if i can get those wires anywhere else.
Posted By: Mark Mizenko
Date Posted: March 04, 2008 at 2:52 PM
Looking to just add a handle to use the factory cruise?
If those Pink Blue and Gray wires are'nt at the backside of that ignition harness junction block either, I think you'll have to add a whole aftermarket system.
Does it have a throttle cable?  V6 or V8?
Posted By: zziggy
Date Posted: March 12, 2008 at 1:26 PM
4.3L V6 needs to have a GM HANDLE and the scs4366 if you want an easy install on the cruise that looks factory.
V8 engines need just the handle.
OR you can go totally aftermarket on the V6 with the scs3342 for about $160 complete.
