’05 spectra vss
Forum Name: Cruise Controls
Forum Discription: Cruise Control Settings, Tach Signal, VSS PPM(Vehicle Speed Signal Pulses Per Mile), Vacuum, Brake, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=103322
Printed Date: May 08, 2026 at 8:24 PM
Topic: ’05 spectra vss
Posted By: mullet904
Subject: ’05 spectra vss
Date Posted: March 22, 2008 at 7:36 PM
Looking to install an after market cruise control on a '05 KIA Spectra, Automatic.  Unable to find VSS location.  Rostra site says ORANGE / black wire from ECM by the driver's R. leg.  My ECM is on the driver kick panel.
Any body have the wiring diagram for an '05 spectra??????????????
Posted By: zziggy
Date Posted: May 24, 2008 at 11:50 AM
Kia Spectra 2000-2005
Use SCS 3342 for Vacuum servo electroonic cruise
Or
SCS 4342 for a n All Electric servo cruise
VSS: At Transaxle, Behind Engine, below and to the right of the brake booster, 3 pin plug, Wire Color: GREEN/ ORANGE
4000 pulse (switches are set)
Hot Brake: White
Cold Brake: Orange
12V Ignition, At Fusebox, empty terminal
Servo mounts to passenger firewall, between shocktower and engine.
Handle mounts in top section of column plastic cover, Top unsnaps.
Posted By: fcss
Date Posted: June 23, 2008 at 4:21 PM
GREEN/ Orange at the drivers side kick panel, 21-pin plug
