91 nissan maxima cruise control
Forum Name: Cruise Controls
Forum Discription: Cruise Control Settings, Tach Signal, VSS PPM(Vehicle Speed Signal Pulses Per Mile), Vacuum, Brake, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=115199
Printed Date: May 09, 2026 at 6:26 AM
Topic: 91 nissan maxima cruise control
Posted By: *chit*
Subject: 91 nissan maxima cruise control
Date Posted: July 20, 2009 at 8:55 PM
the cruise control in my maxima works on occasion but only for brief periods of time before it cancels itself out. I'm wondering if this is an issue with these cars and possibly a common place to start checking for the fault.
Posted By: i am an idiot
Date Posted: July 20, 2009 at 9:13 PM
When you drive, do you rest your foot on the brake pedal? I know you are probably thinking, no way would I do that. Notice next time you drive the car. If it is a standard transmission, do you ride with your foot on the clutch pedal? Notice next time you drive. ------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
Posted By: *chit*
Date Posted: July 21, 2009 at 9:16 PM
I have considered those options too, the brake pedal switch and also the hand brake switch, the car is an auto so rule out the clutch switch. i try to reposition the brake pedal as well as the hand brake while driving to see if anything changes but never has. Unless one of these has an internal fault. The process of elimination begins...
Date Posted: July 21, 2009 at 10:17 PM
The hand brake should light an idiot light on the dash when it is engaged. If the light works, and it is not on, that switch is probably OK. If the foot brake switch is engaging, it will turn your brake lights on. At night, back up to a store front with a lot of glass, gently move your brake pedal while watching in your mirrors, if the light comes on when you barely touch the pedal, it may need adjusting. If you have to move it a good bit to light the lamps, we can rule that one out too.
Posted By: *chit*
Date Posted: July 26, 2009 at 11:10 PM
Excellent ideas, thanks. The hand brake idiot light works but never flickers while driving and the brake pedal switch seems to operate properly even while tapping it or moving it from side to side.
