audiovox ccs 00
Forum Name: Cruise Controls
Forum Discription: Cruise Control Settings, Tach Signal, VSS PPM(Vehicle Speed Signal Pulses Per Mile), Vacuum, Brake, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=122040
Printed Date: May 10, 2026 at 9:25 AM
Topic: audiovox ccs 00
Posted By: timkins
Subject: audiovox ccs 00
Date Posted: May 28, 2010 at 5:47 PM
I installed an Audiovox CCS-100 cruise on a street rod several years ago and I also installed the stock appearing wiper stalk rather than the dash control on/off, set/resume switch. The unit has worked OK til recently. It took an abnormal amount of pressure on the set button and the only way it would work for a while was when I used the resume slider switch on the wiper stalk. Then it stopped working altogether. I went through with a volt/ohm meter and everthing checks out. I then reinstalled the dash switch and disconnected the wiring from the wiper stalk so now I can at least see that there is power to the unit. I then checked the vacuum hoses and the magnet and speed sensor all to no avail. The unit does turn on and off but will not engage. What else can I check? Any suggestions would be appreciated.
Posted By: timkins
Date Posted: May 29, 2010 at 10:45 AM
Thought I checked ALL of the wiring but I was wrong. Checked the four post only did not have power on the brown wire at the unit under the car. Broken wire!! All fixed now thanks!!
