12 volt servo
Forum Name: Cruise Controls
Forum Discription: Cruise Control Settings, Tach Signal, VSS PPM(Vehicle Speed Signal Pulses Per Mile), Vacuum, Brake, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=134505
Printed Date: May 11, 2026 at 5:49 PM
Topic: 12 volt servo
Posted By: myonus
Subject: 12 volt servo
Date Posted: July 08, 2013 at 9:48 PM
Hello, I'm hoping that this would be the correct forum to ask this question; if not forgive my ignorance.
Since cruise controls use servo motors to control accelleration,  I thought this may be a appropriate question.
How much torque could a cruise control servo get away with at a 12 volt car system?
Let me explain more.  If I wanted to try to save some money,  and convert a go-cart into a R/C off road desert dune buggy; would a junk yard cruise control servo give me the torque I would need to control the steering?
Given: that there is a decent amount of steering gear/ linkage to make the turn reasonably at lets say 20 mph.
could it handle brake calipers? or transmission shift?
Be not guided by morality, but rather, integrity.
Posted By: KPierson
Date Posted: July 10, 2013 at 1:41 AM
I wouldn't expect them to be able to pull much. They are designed to open a spring loaded butterfly valve which typically takes very little force to open.
Kevin Pierson
Posted By: myonus
Date Posted: July 10, 2013 at 11:47 PM
Thanks,  how about a motor for a electric window?
