2006 Mazda Tribute cruise control wiring diagram
Forum Name: Cruise Controls
Forum Discription: Cruise Control Settings, Tach Signal, VSS PPM(Vehicle Speed Signal Pulses Per Mile), Vacuum, Brake, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=143662
Printed Date: April 15, 2026 at 10:59 PM
Topic: 2006 Mazda Tribute cruise control wiring diagram
Posted By: sillywilly
Subject: 2006 Mazda Tribute cruise control wiring diagram
Date Posted: October 24, 2017 at 9:06 PM
Does anyone have a cruise control wiring diagram for a 2006 Mazda Tribute?
Posted By: Ween
Date Posted: October 24, 2017 at 9:28 PM
https://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=129476
Date Posted: November 13, 2017 at 3:21 PM
I used the link and printed out the wiring diagram. Thank you!
I need someone's input on the troubleshooting I've done so far.
2006 Mazda Tribute: Cruise control does not engage; light on instrument panel does not illuminate
I checked the following input and output pins on the Speed Control Servo
- pin 7 has 12v with ignition switch on
- verified ground on pin 10
- pin 9 goes from 12v to 0v when the brake pedal is pushed
- pin 4 goes from 0v to 12v when the brake pedal is puched
- pin 6 (which appears to supply voltage to ON/OFF, RESUME, COAST, and SET resistor/switches) has zero volts
Are there any other t/s steps I should take before assuming the Speed Control Servo is bad?
Posted By: Ween
Date Posted: November 13, 2017 at 6:23 PM
Pin 1 @ Air Bag connector should have +12V with ignition on.
Pin 3 @ Air Bag connector should have voltage (unknown value, should be less than ignition voltage) when cruise is switched on at steering wheel.
Pin 2 as Pin 3 above i.e. continuity between 2 & 3 as long as other cruise control buttons aren't pressed. When buttons are pressed voltage (unknown again) will be present.
Date Posted: November 13, 2017 at 10:06 PM
Thanks Ween! Your suggestions make sense.
I have to to to Texas to do some hurricane relief work for a week, so I won't get those measurements until I get back. I'll let you know what I get when I'm back.
Thanks again!
