2001 Dodge Neon VSS
Forum Name: Cruise Controls
Forum Discription: Cruise Control Settings, Tach Signal, VSS PPM(Vehicle Speed Signal Pulses Per Mile), Vacuum, Brake, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=68457
Printed Date: May 07, 2026 at 6:45 AM
Topic: 2001 Dodge Neon VSS
Posted By: iowa_70
Subject: 2001 Dodge Neon VSS
Date Posted: December 15, 2005 at 4:52 PM
Where is the VSS wire located so that I can hook into it for my cruise control.
Thanks in advance
Posted By: airandsound
Date Posted: December 16, 2005 at 1:18 PM
Neon   95-01
SCS/Frigette Cruise #3342
95
At PCM, Drivers Fender, 60 pin plug, Pin #5
Wire Color: WHITE/ ORANGE 8000 pulse
96-01
VSS; 2-40 pin plugs. Pin #66
Wire Color :WHITE/ ORANGE
8000 pulse (switches set)
Hot brake at Brake light switch :
12v at all times
Wire color;Pink/Blue
Cold brake at Brake light switch
12v only when pedal is depressed.
Wire color; WHITE/ Tan
Posted By: iowa_70
Date Posted: January 02, 2006 at 2:29 PM
I'm still having trouble getting it to work. I have a SCS 3310 installed. Any suggestions???
Date Posted: January 03, 2006 at 10:22 AM
set the switches 1, 3 off the rest are on
call 1-800-275-7524 tech service?
