2004 Cavalier cruise control
Forum Name: Cruise Controls
Forum Discription: Cruise Control Settings, Tach Signal, VSS PPM(Vehicle Speed Signal Pulses Per Mile), Vacuum, Brake, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=69346
Printed Date: May 07, 2026 at 12:39 AM
Topic: 2004 Cavalier cruise control
Posted By: big dave 2
Subject: 2004 Cavalier cruise control
Date Posted: December 27, 2005 at 10:38 PM
Cruise control shutting off when turn signals activated. We recently had a remote car starter installed. This car has a manual transmission. What can be causing this to happen? P.S the left turn signal is flashing faster than the right.
Posted By: sparkie
Date Posted: December 28, 2005 at 4:44 PM
Check for a burnt out stop lamp or signal bulb. Some cruise controls will not work correctly if there is high resistance to ground on the switched side of the brake switch. There may also be a ground and or wiring problem with your rear tailights. I have seen this problem many times. If you have ohms meter, measure the resistance to ground on the white wire at the brake switch to a know good ground. If you have more than 5 ohms there is a problem. The usuall cause is one bulb is bad.
sparky
