audiovoxs ccs-100
Forum Name: Cruise Controls
Forum Discription: Cruise Control Settings, Tach Signal, VSS PPM(Vehicle Speed Signal Pulses Per Mile), Vacuum, Brake, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=70725
Printed Date: May 06, 2026 at 5:52 PM
Topic: audiovoxs ccs-100
Posted By: bached41
Subject: audiovoxs ccs-100
Date Posted: January 14, 2006 at 12:02 AM
i have  just installed a ccs-100 into my 05 ford focus zx3, everything works upto to 42 mph then it shuts itself down. i cant set anything above that speed either. i think i have the right VSS wire and there should be enough vacuum at higher rpm. to test that i left it in first and took it up to 30 and it worked. the tach is my only question. i tied in to one of the leads going into the coils( it has coils over every plug). any hints, tips ,ideas would be apreseated greatly.
Posted By: mo12v
Date Posted: January 14, 2006 at 7:01 PM
You may need a Vacuum Resivoir......but it sounds like Throttle slack
Check the slack in your Throttle hook-up.......need approx. 1/8 inch no more
MO
Posted By: hd78bronco
Date Posted: April 24, 2006 at 2:04 PM
Did you ever get your cruise working? I just put the same kit on my 05 focus and it dosen't work at all. I installed a ford tach driver for the tach signal and think I have the proper VSS wire. Anybody have any suggestions? Thanks.
Posted By: NowYaKnow
Date Posted: April 24, 2006 at 6:06 PM
I try not to hookup tach on cruises whenever possible. More times than not it messes things up. I would start there.
Mike
Posted By: trucks
Date Posted: May 15, 2006 at 12:43 AM
 Locating vss wire and where  to hook the wires to the audiovow ccs-100 cruise control so it will operate correctley
