universal worldcruise 250-1336
Forum Name: Cruise Controls
Forum Discription: Cruise Control Settings, Tach Signal, VSS PPM(Vehicle Speed Signal Pulses Per Mile), Vacuum, Brake, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=74398
Printed Date: May 06, 2026 at 5:17 AM
Topic: universal worldcruise 250-1336
Posted By: jmroussel
Subject: universal worldcruise 250-1336
Date Posted: March 13, 2006 at 10:05 AM
I installed a 250-1336 worldcruise from Rostra on a 2005 Kia Rio automatic together with a vacuum reservoir 250-3417; the cruise seemed to surge which is annoying. I've try low sensitivity & high centering Vice/versa but it still does not satisfy the customer. The 250-1105C was a better cruise but is now discontinued. Anybody out there familiar with worldcruise?
j-marc
Posted By: mo12v
Date Posted: March 13, 2006 at 3:32 PM
How did you hook up the throttle?
How much slack is on cable?
The Rostra:  250-1766 may have been better
MO
Date Posted: March 14, 2006 at 9:47 AM
The throttle is hooked-up with the loop cable adapter with 1/4 in. slack and is tied to the throttle bracket with tube clamp.
I did many installations on Rios for the last 5 years with Rostra 250-1076 or 250-1105C and never had a come-back. The dealer was told that this 250-1336 was the replacement for the 250-1105C but it really did not do the same job.
j-marc
