ccs 100
Forum Name: Cruise Controls
Forum Discription: Cruise Control Settings, Tach Signal, VSS PPM(Vehicle Speed Signal Pulses Per Mile), Vacuum, Brake, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=93841
Printed Date: May 10, 2026 at 9:25 AM
Topic: ccs 100
Posted By: va2ir
Subject: ccs 100
Date Posted: May 12, 2007 at 8:23 AM
I'll address this posting to Sparky.    If you remember back to last fall, I have the 73 Ford Torino with the CCS-100 install.
Summer of 2006, it became intermittent, finally failing in August 2006.
I went thru all your tests, checked all the wiring, magnet sensor is working, rear lights are ok, resistance to purple wire to ground is 5 ohms (5.2 I think).  Vacuum is plentiful.  Voltages are all correct, chassis ground is good. As I had stated, this unit worked well for 2 years and thousands of miles.
Am I looking at a bad servo?  I have read some good and bad reports on these kits - and my local installer doesnt even touch them anymore.
Questions:  Is there any way to bench test this unit off car?
Is there a factory cruise model, i.e. GM, FOrd, Chrysler, Nissan, Toyota etc where the servo would be compatible with the Audiovox unit?  I realize it will not be plug and play and will need a mod on the wiring harness.
Bite the bullet and get a new kit?  If I could get this unit to engage on the bench, then I would know its wiring.  But I really doubt  its wiring.
Ian in Montreal
Posted By: va2ir
Date Posted: May 22, 2007 at 11:05 AM
UPDATE:
I picked up a complete new kit from a local distributor.  I replaced the servo only, again after checking all my wiring.
Works perfectly with the new servo.  I guess the old one crapped out.
Wish I had a schematic for it.  Maybe could be repaired.
Ian
Posted By: sparkie
Date Posted: May 23, 2007 at 5:02 PM
I am happy to hear you got it going. The units are reliable from my experience, so I believe you did the right thing.
sparky
