96 toyota rav4, cruise control
Forum Name: Cruise Controls
Forum Discription: Cruise Control Settings, Tach Signal, VSS PPM(Vehicle Speed Signal Pulses Per Mile), Vacuum, Brake, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=94663
Printed Date: May 10, 2026 at 3:59 PM
Topic: 96 toyota rav4, cruise control
Posted By: rod51
Subject: 96 toyota rav4, cruise control
Date Posted: June 10, 2007 at 6:35 AM
  i have a 96 toyota rav4 automatic wanting to put cruise contol in it, i bought a audiovox ccs-100 electronic cruise control need the wiring diagram to put this in 96 toyota, the colors of wires on the auidvox is red, brown, gray, green, yellow, black needing to know what color  wires they hook up to in a 96 toyota rav4 2.0 i thank you in advance,  rod51
1096 RAV4 cruise control wireing, putting in a universial cruise control, need help in what colors wires do I hook up on the RAV4 to a universial cruise control Thank you in advance
Posted By: sparkie
Date Posted: June 10, 2007 at 8:42 AM
Use the link on this page under the cruise control section to get the vehicle info. The wiring info is contained in the cruise control install manual.
sparky
