ignition coil vs tach signal wire
Forum Name: Cruise Controls
Forum Discription: Cruise Control Settings, Tach Signal, VSS PPM(Vehicle Speed Signal Pulses Per Mile), Vacuum, Brake, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=96054
Printed Date: May 10, 2026 at 7:33 PM
Topic: ignition coil vs tach signal wire
Posted By: mitchell2345
Subject: ignition coil vs tach signal wire
Date Posted: July 30, 2007 at 8:02 PM
I am going to be installing a cruise control unit, Audiovox CCS-100. The instructions say to connect the blue wire to the negative side of the ignition coil. On my 99 Mazda Protege Rostra's web site gives me the color of the Tach Signal Wire. Is this the same wire? Will it work?
Thanks,
Mitchell
Posted By: ringojam
Date Posted: July 30, 2007 at 8:35 PM
Should not be a problem you are only trying to sense rpm.
------------- Jamaica home of the worlds fastest man.
Date Posted: July 31, 2007 at 8:35 PM
cool, i couldnt find the ignition coil anyhow.
Date Posted: August 02, 2007 at 1:27 PM
So after installing everything it didnt work :(
I was sure that it had to do with the VSS & Tach wire not being correct. I went to a local installer and he looked in his installer only pages and connected the VSS & Tach wire to the right locations. Now the unit is still not working.
What do i do from here? Could it be insufficient Vacuum? Could i have blown the cruise control computer by hooking it up wrong? How can i test this. I really hate to return and give up. So far I have the $100 into the kit and paid the professional installer $60 for his hour of labor and expertise.
Thanks,
mitchell
Posted By: airandsound
Date Posted: August 14, 2007 at 9:22 AM
No tach signal needed with the scs/frigette cruise.
