criuse control problems
Forum Name: Cruise Controls
Forum Discription: Cruise Control Settings, Tach Signal, VSS PPM(Vehicle Speed Signal Pulses Per Mile), Vacuum, Brake, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=96102
Printed Date: May 10, 2026 at 6:28 PM
Topic: criuse control problems
Posted By: corndogg
Subject: criuse control problems
Date Posted: August 01, 2007 at 4:12 PM
my 1998 honda preludes cruise control has worked 1 time the fuses are good and the linkage is all hooked and the switch is well within its specs what else should i look for thank u much
Posted By: eurobink
Date Posted: September 07, 2007 at 1:12 AM
if a cruise does not activate.. assuming the unit is good, these are the only possibilities
  • your brake wire connections are improper
  • your VSS wire is incorrect or faulty.
anything else would still give you some kind of response. Im also assuming its an electronic cruise control
