2007 kia rio cruise
Forum Name: Cruise Controls
Forum Discription: Cruise Control Settings, Tach Signal, VSS PPM(Vehicle Speed Signal Pulses Per Mile), Vacuum, Brake, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=96169
Printed Date: May 10, 2026 at 5:17 PM
Topic: 2007 kia rio cruise
Posted By: wowbw7
Subject: 2007 kia rio cruise
Date Posted: August 04, 2007 at 10:02 PM
need help with wiring diagram to install a Audiovox CCS100 Universal Vacuum Cruise Control in girl friends 2007 Kia Rio. any help would be appreciated. thanx in advance
Posted By: eurobink
Date Posted: September 07, 2007 at 1:09 AM
yea.. how about you return the vacuum cruise and get an electronic...
then follow the procedure of a cruise install and the only wire you are missing is the VSS, it's at the diagnostic plug under the dash.. also found behind the cluster panel.. i think its like a yellow with black.. or some weird color like that.. ive done like 40 of them..
