vss wire on 89 toyota pickup?
Forum Name: Cruise Controls
Forum Discription: Cruise Control Settings, Tach Signal, VSS PPM(Vehicle Speed Signal Pulses Per Mile), Vacuum, Brake, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=98493
Printed Date: May 10, 2026 at 2:07 AM
Topic: vss wire on 89 toyota pickup?
Posted By: remedy541
Subject: vss wire on 89 toyota pickup?
Date Posted: October 31, 2007 at 1:53 PM
Installed a Rostra cruise on an 89 Toyota Pickup, couldn't find VSS wire info anywhere, so used a magnet switch. Worked once then quit. Anybody know if there is a VSS wire on those trucks? Any info much appreciated. Thanks.
Posted By: airandsound
Date Posted: November 13, 2007 at 4:25 PM
The VSS is extremely easy to find on the Toy truck.
86 –94 Toyota PU 4 cyl and V6, 86-95 4-Runner
VSS: Passenger Kick panel Wire Color, GREEN/ BLUE 4,000 pulse, (switches are set)
V6 ECM 24 pin plug, 22 pin w/ect
86-87 4cyl Carb (calif) 13 pin plug ECM
88 carb, calif 9 pin plug, ECM
89 carb calif 12 pin plug ECM
86-91 EFI (w/ECT) also 3Vz-E w/ECT 22 pin plug ECM
86-91 EFI (w/o ECT) 14 pin plug ECM
90-91 3Vz-E w/o ECT 24 pin plug ECM
92-95 at ECM, passengers kick panel, small plug Wire Color: GREEN/ BLUE 4000 pulse (switches are set)
