my box for 99 ford f150 supercab
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=101521
Printed Date: May 14, 2026 at 5:33 AM
Topic: my box for 99 ford f150 supercab
Posted By: 12voltrules
Subject: my box for 99 ford f150 supercab
Date Posted: January 24, 2008 at 2:46 PM
I decided I wanted a special sealed enclosure to house my new Memphis Audio PR15-124 SVC subwoofers. This was my first ever enclosure project.
To start I bought a 8x4 sheet of 3/4 MDF from home depot like this..
posted_image
Date Posted: January 24, 2008 at 2:49 PM
After I made all my calculations and drew out the pieces I went ahead and cut them out to see how they butted together. In this case it worked out suprisingly nice the first time around.
posted_image
posted_image
Date Posted: January 24, 2008 at 2:57 PM
After butting them together I also realized that my backing piece wasn't tall enough and didn't have a 45 degree angle to accommodate the top piece so I was forced to cut out a new one and miter cut the angle. No big deal.
After screwing together all the main pieces and sealing them with silicone, it was time to mount the top piece. I had already drawn my holes and cut them with a jig saw to fit the 12 inch subs perfectly.
The top fit nicely, except for a little lip at the bottom that I sanded down and sealed later on before upholstering the box. Miter cuts with a big old skill saw are tricky!
posted_image
Date Posted: January 24, 2008 at 3:02 PM
Here is the enclosure after being completely screwed together, sanded, and sealed with silicone on the inside. Now ready for the fabric that I purchased from Joann fabric store..
posted_image
Date Posted: January 24, 2008 at 3:08 PM
Here is the finished box. The enclosure holds 1.5 cubic feet of air for each sub woofer. I used drywall screws to put the whole thing together and I used 3M spray glue to carpet the box. I would like the the12volt.com for all the info and calculators that I used to build this. Installed photos coming soon. Hope this helps for some people.
posted_image
Posted By: joyrydn
Date Posted: February 04, 2008 at 8:18 PM
First off, is that an extended cab or a crew cab 4 door? and did you take out your back seat?  i would like to see pictures of the finished box with the subs in and in the truck. i have a 2003 f150.  but i also have 2 kids so i have to mount the box under the back seat and i have an extended cab so i only got .7 cu ft in each chamber, but went with 2 12'' earthquake sws subs and a 1000 watt earthquake amp.  it is loud yes, but that is what i was going for.  i am however contemplating taking out the center seat in front and custom fabricating a fiberglass encosure to get more air space and a harder hit out of it.  when i get around to that i will start a tpoic on that alone, but its wisconsin and its cold, so im screwed. lol.  anyway let me know more on ur ride i love ford trucks, would be nice to see what else you have done.  props!
Make it Euro'n!!!
