Fiberglass and plastic
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=10345
Printed Date: June 08, 2024 at 7:27 AM
Topic: Fiberglass and plastic
Posted By: messiah9966
Subject: Fiberglass and plastic
Date Posted: March 03, 2003 at 9:54 AM
I was building some kick pods for a vehicle and i wanted that factory fit. To make it easier i thought i would use the factory kickpanel as my backing. i attached the speker rings to it, strecthed some grill cloth around the pieces and glued the cloth on to the back of the kickpanel and then resined it. When i was sanding it down i noticed that the glassed cloth was separating and peeling back from the factory plastic panel! How do you get the glass to stick and become part of the factory plastic?
Posted By: audiomechanic
Date Posted: March 05, 2003 at 9:25 AM
you can use dura mix.....it will adhere to the plastic and allow you to glass to it. it pretty much sticks to everything and your glass will stick to it quite well.
here is a link to a site that you can get it from....
https://www3.3m.com/search/search?request=searchKeyword&query=duramix+
Posted By: speakermakers
Date Posted: April 02, 2003 at 9:33 PM
I recently read some where that there is a chemical that can be mixed in to polyester resin along with some scraps of ABS plastic to form a final mix that will bond with any abs plastic part. But now I can’t find that article. Dose anyone Know what chemical this is?
------------- speakermanshead
Date Posted: April 03, 2003 at 9:41 AM
it was mobile electronics industry mag. it was a 50/50 mixture of MEK and abs scraps. it does work. it takes a bit of time for the MEK to soften the abs. it is good for sticking 2 plactic pieces together. you will want to sand the 2 pieces with some 36 or 50 grit to give it more adhesion. it also works well for seaming 2 pieces of abs together.
Posted By: drvnbysound
Date Posted: April 03, 2003 at 3:45 PM
Another way of permanently attaching fiberglass to ABS, is to make "fiberglass rivets" per say. Drill holes in the ABS, and fiberglass some matting and resin to each side of the hole allowing the resin to bond inbetween.
Posted By: ice4life8269
Date Posted: April 07, 2003 at 8:01 PM
Hey, what is this MEK stuff? is it the same stuff the military uses?
Date Posted: April 07, 2003 at 9:23 PM
if they shop in the paint section of home depot ....
it can be used as a thinner for resin....or in this case to soften plastic.....there are a bunch of uses.
it is pretty much the same as acetone...just evaporates slower.
Posted By: lycoming
Date Posted: April 18, 2003 at 7:11 PM
You can't stick any kind of fiberglass to ABS plastic. not if it is under any load anyway. As for the MEK and ABS pieces for glueing ABS -- have you heard of ABS glue? Plumbing section of your local hardware store. It's cheeper than MEK. Note: MEK is totaly different than MEKP -------------
Posted By: sh2owski
Date Posted: April 18, 2003 at 7:41 PM
MEK is Methyl Ethyl Keytone. It's a pretty common hydrocarbon solvent. Look at your local DIY Home improvement store in the paint section.
Posted By: dishshacker200
Date Posted: April 18, 2003 at 9:55 PM
the best thing that i would sugest would be a product from norton or proform ita metal bonding adhisive bond almost anything together metal to plastic plastic to metal smc to metal woos to smc ... you get the ieda just go donwn to youre local automitive shop it will be under autobody ask them for it they come in difrent drying time the fastis is 3 minute and the longest is about 1 hour this is good stuff
