how to keep mounting ring clean.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=106188
Printed Date: May 14, 2026 at 2:17 AM
Topic: how to keep mounting ring clean.
Posted By: tschicky
Subject: how to keep mounting ring clean.
Date Posted: July 17, 2008 at 1:33 AM
I am working on my first fiberglass project and it is going good so far but I could use some advice that I hope will save me time later.
I currently have the back, bottom and 1 side of my enclosure fiberglassed. I have a mounting ring up front and have stretched and resined fleece for the remaining sides. The mounting ring was done in a recessed style and was cut to very tight measurments. The sub fits in with no gaps around it which is what I want. However I am concerned about resin and fiberglass running and causing extra unnecessary sanding later. How do I keep the ring free of rouge fiberglass/resin? Any ideas would be great.
I have looked at the "How to build a fiberglass enclosure" and see some amazing work but do not know how he kept the ring so clear of material.
Posted By: Melted Fabric
Date Posted: July 18, 2008 at 1:27 PM
Tape, foil, etc... something to mask it while you get messy.
------------- I have not failed. I've just found 10,000 ways that won't work.
When you do not know what you are doing and what you are doing is the best -- that is inspiration.
