water in the door
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=108289
Printed Date: May 14, 2026 at 12:16 AM
Topic: water in the door
Posted By: j-dub-1989
Subject: water in the door
Date Posted: October 20, 2008 at 10:28 PM
if someone could help me figure out why water keeps getting in the door of my 2003 monte carlo
Posted By: i am an idiot
Date Posted: October 20, 2008 at 10:36 PM
Because it rains. It is normal for water to get inside the door, is it not draining out?
Posted By: ckeeler
Date Posted: October 20, 2008 at 11:25 PM
no water gets in mine.  have you always owned this car? has it ever been in a wreck that you know of?  has the outside window felt at the bottom of the window and top of the door ever been replaced?
Posted By: megaman
Date Posted: October 20, 2008 at 11:55 PM
depends on how much water?  If it's just enough to make the bottom wet, then your seals most likely need to be replaced.  If the bottom fills with enough water for a pet gold-fish, you have another issue altogether.
Date Posted: October 21, 2008 at 12:19 AM
it was in one accident but not a bad one and it has a nice amount of water in it is there anyway to fix this problem because it keeps messing up my door speakers
Date Posted: October 21, 2008 at 4:53 AM
If it is holding water there is a problem with the drain system inside the door. I have yet to find a vehicle that did not let water in the door when it rained, the internals of the door are designed to have the water drip away from speakers, motors and control switches and to the inside of the outer skin and then drain through usually a series of slots or holes on the bottom of the door.  We have an Impala in the shop right now, there are 2 holes at the bottom of the door.  One in the very front and one in the very rear of the door.  The purpose of these holes is to drain water.  If your door was damaged in the accident, maybe they put Bondo over the holes.
Posted By: jayson33
Date Posted: October 24, 2008 at 12:18 AM
Replace lower outside window seal Also clean the drain on the bottom side of door it should be in the back
corner of the door
My wife thinks bagging a truck means you kick it in the truck nuts
