Integra Gauges
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26607
Printed Date: June 14, 2024 at 5:35 AM
Topic: Integra Gauges
Posted By: tonto26
Subject: Integra Gauges
Date Posted: February 16, 2004 at 10:45 PM
Anybody put glow guage faces in a 96 Integra AT? If so, do the needles have to be removed? Also, Which ones are best?
Posted By: auex
Date Posted: February 16, 2004 at 11:19 PM
I put them in my civic and the needles DO NOT get removed, they just slide over them. If you remove them they will not go back in. My Temp gauge hasn't worked since.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: Velocity Motors
Date Posted: February 16, 2004 at 11:40 PM
Remove the two screws that are holding down the existing gauge & slide the center of the new gauges over the end of the needle and slide it to the center of the pin. Becareful not to put too much pressure on the center of the neddle as this will break the needle off at the coil and will require you to replace that guage.
------------- Jeff
