Fiberglassing Dash
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=41312
Printed Date: February 08, 2026 at 3:54 AM
Topic: Fiberglassing Dash
Posted By: jortiz
Subject: Fiberglassing Dash
Date Posted: October 20, 2004 at 4:24 PM
I have a 97 nissan pikcup dash that I want to modify in order to get the "gel coat" look, but I have a couple questions on how to get started.
1. Do I remove the vinyl of the dash before I do
   anything?
2. Can I just resin the dash or do I have to apply
   fiberglass?
Any help on the process would be appreciated. Thanks
Drop it, Bagg it, & Drag it!! Nissan 4 Life
Posted By: gta94integra
Date Posted: October 20, 2004 at 11:16 PM
I havent glassed my dash yet but plan to.  I did glass my door panels in my integra and its basically the same process.  You will need to remove the vinyl.  Just resin alone will be too brittle and will crack off.  If the dash is plastic underneath the vinyl, you will need to ruff it up real good with sandpaper and i would suggest drilling small holes all over to give the glass something to hold onto.  Do some trial and error on some inconspicious spots and you'll find out what works.  When all else fails...sand it down and start over.
Posted By: shesaidshewas18
Date Posted: October 22, 2004 at 1:52 PM
I drive a 2001 Eclipse and Ive painted my interior various colors. Unfortunately, when you mix enamel and acrylic, the paint tends to bubble in heat, and I found that out the hard way. In the Eclipse the part of the dash that covers the gauges... I have 2 of those things. I plan on fiberglassing one of them, so I can just sand down the fiberglass real smooth then re-paint. I'll let you know how it goes.
BTW, do you know how hard or easy it is to sand fiberglass?
Date Posted: October 22, 2004 at 2:11 PM
Fiberglass isn't the easiest thing in the world to sand.  I would suggest starting with a D/A (dual action) sander with about 36 grit...real rough.  Then once you get it shaped, you can start with your bondo and working up to about 150 grit.  You'll get the hand of it.  Once you think you've got it ready to prime and you put the first coat of primer on it, you're gonna notice all the little imperfections in it.  It'll take a while to get it perfect but keep sanding and bondoing then put a few coats of filler primer on it and sand it with some high grit paper then start wet sanding and you'll soon be ready to paint.
    A valuable tip is to wear long sleeves, pants and gloves when sanding because fiberglass dust doesn't play when it gets in your skin...it sux.
Posted By: hersheyloc
Date Posted: October 22, 2004 at 3:13 PM
Hey, did you every think about making the dash look totally custom? I have a 89 Civic, and what I did with my dash was wrapped the thing in fleece. This made it look like an entirely different dash. It takes a little bit of time to wrape it, but once you have, you'll have line that no one else will have. Theres a link to mine.
https://groups.msn.com/Hersheylocsgroup/car.msnw?action=ShowPhoto&PhotoID=332
Posted By: jortiz
Date Posted: October 24, 2004 at 3:33 PM
Thanks for all the info. Hey Hersheyloc that dash looks clean. Did you add layers of mat to the fleece or just used the fleece a lone with resin? If you can, explain the process you did with your dash. Thanks
Date Posted: October 25, 2004 at 2:17 AM
After I resined the fleece, I added one layer of mat. The fleece was pretty thick, so it was tough. The only thing with really thick fleece is that it doesn't soak all the way through in some spots, unless you put tonnes of resin, which can get costly. I would suggest goin and getting some Tshirt material. My friend and I got some at a Fanny's Fabric store for like $3 a yard. It was kinda like white muscle shirt material. Stretchy both ways. Resin that, then mat it until you think its solid enough. I put a final layer of resin alone all over, just to fill in some pits, so the bondo part of the project wouldn't take as long. I took a dremel and cut away any of the excess around the edges, to get clean edges.Then I put bondo all over, and sanded. The more bondo, and more sanding. The primed, wetsanded, and painted. Thats about all really. Most of the posts on this site are really helpful. Hope that helps too.
Oh one more thing. In my car, I found that there were like 20 different places where the dash was mounted. I reduced that to like 5 or 6. Its really not needed to have that many screws holding it in place. So know what of the mounts ur gonna use, so you dont glass them by accidentposted_image. And getting it in is harder then getting it out! Trust me. I was up till 6 am figuring that one out.
