Routing Lexan?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=41601
Printed Date: February 08, 2026 at 5:14 PM
Topic: Routing Lexan?
Posted By: D'Ecosse
Subject: Routing Lexan?
Date Posted: October 25, 2004 at 1:35 AM
Anyone routed Lexan? My friend needs some louvre slots cut in a rear window /engine hatch. I don't think it will be a problem, but any advice would be appreciated re cutting speed etc. I figured I'd try to keep the bit speed down a little, keep the tool moving & try to "bite" as little as possible. I'll lay out the pattern on MDF and just use that as a template with a pattern cutter.
Posted By: Alpine Guy
Date Posted: October 25, 2004 at 8:49 PM
i seen on tv where the guy took a razor blade, , "very sharp one"  Cut the lexan as deep as possible in 1 or 2 passes,,,then pour alcohol in the groove, , light it on fire and bend it off.   It cuts perfect.   But that was for big curves and straight lines, , , if its a really tight curve, then that prolly wont work.
Posted By: chrane
Date Posted: October 26, 2004 at 8:50 PM
lexan is easy to router, but get a friend or hire an imigrant to spray wd-40 on the blade and the plastic every 2 seconds or so to keep it cool so it cuts smooth
Aaron
Posted By: CarAudioHelp
Date Posted: October 27, 2004 at 8:50 AM
You've got the right idea with the MDF pattern. A tip to improve and reduce your finishing time. Make two templates, one about 1/16" bigger than your finished template. Route to that line first and then go back and finish off with the correctly sized template. By removing only a small layer on the final pass you will get less chipping which means less sanding/buffing.
Posted By: D'Ecosse
Date Posted: October 27, 2004 at 9:29 AM
CarAudioHelp wrote:
...Make two templates, one about 1/16" bigger than your finished template. Route to that line first and then go back and finish off with the correctly sized template. ....
That's a great tip! Thanks!
