My first fiberglass projects
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=42412
Printed Date: May 13, 2024 at 9:18 AM
Topic: My first fiberglass projects
Posted By: 1hot944
Subject: My first fiberglass projects
Date Posted: November 06, 2004 at 10:24 PM
Iv'e been watching this site for a while and have gotten alot of good info from all of you, many thanks! I decided to register and share my project with others in this forum. I'm working on my 1985.5 Porsche 944 non turbo. Many of the Porsche pureists would cringe to see what I will be doing with my car (sortof de-porsching it a bit) but I want a unique car. Here's some photos of the current state of my project. I welcome any comments and I hope I can ask some of you some questions on car audio in future. :D
------------- In a world full of copycats, it's great to be an original!
Posted By: r0yal
Date Posted: November 07, 2004 at 12:52 AM
same prob with you too...forgot the .jpg lol
Posted By: r0yal
Date Posted: November 07, 2004 at 12:55 AM
Its hard to tell from those 2 pics on what exactly it is, but I checked out your cardomain page, and it looks like you got ALOT more work to do... but the end result should look pretty kick ass! :) keep us updated!
Posted By: 1hot944
Date Posted: November 07, 2004 at 12:05 PM
Thanks, I basically removed the rear seats and am turning the seat cavity into a speaker box for Xplod 6x9's , then I molded some pods for the Xplod 6.5" speakers. I will have Xplod 5.25" in the door panels in custom pods and tweeters on the A-pillers. I am mounting 3 Sony amps in the trunk and a Xplod 12" sub in the spare tire well. I'm going for sound quality rather than power / spl. If you noticed I have removed the rear hatch and made a custom rear deck with a trunk. ------------- In a world full of copycats, it's great to be an original!
Posted By: audiopro111
Date Posted: November 08, 2004 at 1:42 AM
I like the concept but i don't get why u went with SONY XPLODE for the kind of $$$ your probably putting into this car i would have gone with a higher end audio like ALPINE for exaple.
------------- AudioPro111
Posted By: 1hot944
Date Posted: November 08, 2004 at 8:07 AM
Yes I will be spending quite a bit on the car but I can't afford to spend a ton of $$$ on a sound system.I would much rather hear my engine revving. The Sony Xplod stuff is within my budget and I'm spending more on my suspension,performance, braking system and paint. As long as the sound is clean I don't need alot of volume or power. Thanks for your input P.S Porsche parts aren't cheap!!! ------------- In a world full of copycats, it's great to be an original!
Posted By: celica2kgts
Date Posted: November 08, 2004 at 8:35 AM
can always upgrade audio later too
Date Posted: November 08, 2004 at 12:00 PM
thats true just do you!
Posted By: 1hot944
Date Posted: January 30, 2005 at 10:28 PM
Did some more work on my sub bin
Posted By: Carbonb
Date Posted: January 30, 2005 at 11:00 PM
You should of worked on making it smoother when you pulled the material.
A lot of creases that will seriously increase your work load.
Posted By: 1hot944
Date Posted: January 31, 2005 at 10:42 AM
Actually it is quite smooth,its just the way the resin went on that makes it look creased. We'll see what the final result shows ------------- In a world full of copycats, it's great to be an original!
Posted By: sinisteraudio
Date Posted: January 31, 2005 at 12:01 PM
ya but if you took your time you can get it to lay down so its just exactly the same smoothness as the outside will be . here is a pic of a box i did with a really thin coat of bondo over it
Posted By: 1hot944
Date Posted: February 04, 2005 at 11:11 AM
Update of progress Feb 4/05 Second coat of filler. Still a lot more sanding to do.
Date Posted: February 04, 2005 at 12:00 PM
if i can see it right it looks like you just have a common chamber for all of ur speaker. right?
Posted By: 1hot944
Date Posted: February 05, 2005 at 10:28 PM
No, actually the subs are in a sererate enclosure from the 6x9's. I had built the sub enclosure over the previous one so the two would be seperate. Hard to see from the pictures. If you go to my cardomain page, https://www.cardomain.com/id/irricanian you can see what I did. ------------- In a world full of copycats, it's great to be an original!
Posted By: realitycheck
Date Posted: February 07, 2005 at 7:37 AM
Awesome job man, looks like you have been doing a whole lot of work. Good job though, i'm thoroughly impressed in how its coming along.
------------- Learning the trade one fiberglass creation at a time!
Posted By: 1hot944
Date Posted: February 20, 2005 at 3:08 PM
Thanks, I was hoping to get some more done but the weather has not been co-operating. I went to World of Wheels here in Calgary yesterday and took a few pics of some installs and thought i would share them. The Viper trunk with the two triangular subs had plexi covers over the amps which were lighted and had fish tank bubblers as well. I hope none of the owners mind me putting up pictures of their fine work. ------------- In a world full of copycats, it's great to be an original!
Posted By: 1hot944
Date Posted: February 23, 2005 at 9:42 PM
Some update pics, I've sanded and put 1st coat of primer on. Now I am going to do a few touch ups and sand before putting on the next primer coat. I also sprayed some sound deadening material on the inside. I just dropped my subs in to have a look . Were getting some nice weather here in Calgary so I might have some more pics by the weekend. ------------- In a world full of copycats, it's great to be an original!
Posted By: doc t
Date Posted: March 01, 2005 at 5:46 AM
although i can't see the pics at work, i'll look when i get home, just keep us updated.
All Bleeding stops.....eventually!
