any form of shapable acrylic or plastic?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=50691
Printed Date: May 28, 2024 at 7:04 PM
Topic: any form of shapable acrylic or plastic?
Posted By: WILL85IROC
Subject: any form of shapable acrylic or plastic?
Date Posted: February 23, 2005 at 2:48 PM
i need some form of shapable mirror, acrylic, plastic, etc that can reflect light??? is there any such animal??? i need small peices to cut out that will reflect LED's, etc..... can someone point me in the right direction??? thanks :oops:
------------- " WILL85IROC "
Posted By: realitycheck
Date Posted: February 23, 2005 at 3:19 PM
I dont know of anything that is like that but you could take a piece of whateve you wanted too in the shape you want and then put duct tape on it. I call this stuff aluminum tape. Not the cheap grey stuff you get at wal mart. Im talking about the actual aluminum tape that you roll off and then have to peel the white backing off of it to reveal the sticky.
------------- Learning the trade one fiberglass creation at a time!
Date Posted: February 23, 2005 at 3:27 PM
where do i buy it???? is it strong???
Posted By: djdaveoc
Date Posted: February 23, 2005 at 10:48 PM
https://www.selectproducts.com/------------- Plan, Research, Do
Posted By: doc t
Date Posted: February 24, 2005 at 6:22 AM
Its used for repairs in metal and air conditioning ducts it comes in different thicknesses, should be strong enough for your application. just make sure you smooth it out as best you can for the best reflection.
All Bleeding stops.....eventually!
Date Posted: February 24, 2005 at 7:24 AM
whats it cld, can't find it on that site.. thanks
Date Posted: February 24, 2005 at 8:00 AM
Here you go will, If you need a link to the page I found it on here you go. https://arnoldservice.com/hvac_supplies.htm I would go to any local heating and air supply shop you have and ask them for it they will know exactly what youre talking about. ------------- Learning the trade one fiberglass creation at a time!
Date Posted: February 24, 2005 at 8:04 AM
AAWWW MAN!!! THANKS!!!! ------------- " WILL85IROC "
Date Posted: February 24, 2005 at 11:06 AM
No problem buddy.
