How many layers at one time
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=56489
Printed Date: May 09, 2024 at 6:35 AM
Topic: How many layers at one time
Posted By: cubinbob
Subject: How many layers at one time
Date Posted: May 26, 2005 at 3:39 PM
how many layers of fiberglass mat can you lay at one time. I did one at first but that is just a waist of brushes. So i did two at the same time and it came out good. Can i do three or four.
Posted By: 5150azn
Date Posted: May 26, 2005 at 4:35 PM
I say as many as you can handle. I lay as much as I can. The only thing that limits me is the resin, how much can I lay before it starts getting hard.
------------- Tell the Snap-On guy I'm not here!
Posted By: cubinbob
Date Posted: May 26, 2005 at 4:48 PM
that is the answer that made my day. Thanks alot
Posted By: cubinbob
Date Posted: May 26, 2005 at 5:18 PM
ok one last question. it is a 9 cubic feet box for 4 12 in a single ported chamber. About how many layers should i do. I was thinking six layers of fiberglass mat and the one layer of fleas that i started with. What do yall think
Posted By: Velocity Motors
Date Posted: May 26, 2005 at 7:29 PM
3/8 - 1/2 " braced for that kind of enclosure. Otherwise you will see flex in the enclosure. Make sure you brace that enclosure as well otherwise you will need it to be thicker ------------- Jeff
Posted By: cubinbob
Date Posted: May 26, 2005 at 8:13 PM
just the top or 1/3 is made from fiberglass. It is still a big chunk from the totall box.
Date Posted: May 26, 2005 at 9:01 PM
Better safe than sorry when constructing an enclosure that is made from two different materials. The thicker the top portion it, the stronger the overall enclosure will be espcially if you have the weight of 4 woofer's on the top.
------------- Jeff
Posted By: oonikfraleyoo
Date Posted: May 27, 2005 at 9:16 AM
Also, if you layer too many (more than like 10) at once your project may end up warping out of shape from the heat. ------------- Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
Posted By: modena0
Date Posted: May 27, 2005 at 9:47 AM
given that i have not done that many layers at once, i wouldnt know that, but i had thought that it only heated up really hot if there was an overuse of hardener, and also i would imagine once you got to 5 layers, the first layer or two would already be partially cured, again depending on hardener use.
Posted By: racer427
Date Posted: May 27, 2005 at 12:20 PM
To be safe, I would not lay down more than 2 layers of glass at a time, it will be easier to work out any air bubbles that will pop up plus there is a chance that the work will warp a bit. If you are concerned about materials, just use the 50 cent cheapo brush's and small cheap mixing containers. Chris ------------- Alpine CDA-9833 HU
Diamond Audio M661 Components
MTX Thunder T6.6 Components:rear fill:
Cadence Q400 4 Channel Mains + rears
Thunder 801D Subs
MTX 1004 10's
Dual 4g wire to rear
4g grounds
