center console
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=56861
Printed Date: May 23, 2024 at 4:00 PM
Topic: center console
Posted By: popeye004
Subject: center console
Date Posted: June 01, 2005 at 11:08 PM
hey guys can anyone help me out I am working on a center consol I was going to bondo it it is made out of fiberglass but i decided to vinyl it so my question is how do I adhere the vinyl to the consol what kind of glue do i useI was going to use the 3m spray on glue
Posted By: auex
Date Posted: June 01, 2005 at 11:28 PM
That cannot be vinyled in one step, don't even try it. If you are intent on vinyling that then you should learn to use a sewing machine or take it to an upholstery shop.
You may be able to get away with vinyling the top and carpet the sides, maybe.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: ChrisZ3
Date Posted: June 02, 2005 at 6:11 AM
Why not texture coat it? It's much easier. am gonna finisch my box that way also. Curves on my box are too sharp to finish with vinyl.
Posted By: One_Dieu
Date Posted: June 02, 2005 at 11:18 AM
What is this console going into? We love pictures here do you have more? ------------- Respect the Blood Line
Date Posted: June 02, 2005 at 11:22 AM
why cant i vinyl it what if it use really good glue
Posted By: oonikfraleyoo
Date Posted: June 02, 2005 at 1:13 PM
Vinyl will not stretch that much. You could flock it though. ------------- Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
Date Posted: June 02, 2005 at 3:32 PM
Flock it what does that mean?
Posted By: auex
Date Posted: June 02, 2005 at 6:38 PM
Flock is simulated suede. You glue, shake on the suede material, let it dry, then lightly brush off the excess. Vinyl cannot conform to complex shapes, vinyling a simple fiberglass box can be hard. On curves it must be heated and stretched, and it can only stretch so much. I will go as far as to say that it would be impossible to do that with one single piece of vinyl.
Date Posted: June 02, 2005 at 6:46 PM
Flock that it! I made a coffie table once that opened up and I wanted to suede the inside but noone knew what I was talking about where can I buy this spray in suede.
Date Posted: June 02, 2005 at 7:33 PM
Select Products Click "Catagory A-Z" then go down to Suede Flocker.
It's not really spray in but it's really easy, idiot proof even. ------------- Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
Posted By: ChrisZ3
Date Posted: June 03, 2005 at 1:49 AM
flock not so a good idea. It depends how the interior of yr car is finished. If your dash and seats are already suede then go for flock. Otherwise you can texture coat and spray on the same color as the color of your dash parts for a factory look.
Date Posted: June 03, 2005 at 3:37 PM
yeah thats what I was going to do I accually got the same color vinyl but people say it will be hard to vinyl this consol as one peice so I might stich it and glue it.
