Mixing Bondo, Resin, and Acetone?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=57267
Printed Date: May 13, 2026 at 10:12 PM
Topic: Mixing Bondo, Resin, and Acetone?
Posted By: 1sic88hatch
Subject: Mixing Bondo, Resin, and Acetone?
Date Posted: June 08, 2005 at 12:06 AM
I was wondering if mixing Bondo, Resin and acetone will give me a nice smooth finish on my FG inclosure. I've tried glazing putty but I just cant get rid of all the pits. If anybody could help me out that would be great. thanx
------------- 1 bad azz civic....Its Murda!!
Posted By: j68rh
Date Posted: June 08, 2005 at 4:03 AM
I just kept sandinging and filling with bondo until they are all gone. its time consuming but it works.
Posted By: abovestock
Date Posted: June 08, 2005 at 4:21 AM
DON'T use bondo, it is 40 year old crap. Rage Gold and metal glaze work very well to fill and remove pin holes in prep for painting.
Posted By: Lincolnman
Date Posted: June 09, 2005 at 10:44 PM
hatch,
Yeah I saw on here where some guy did a box for a beamer and used the mixture that you were talking about. He said that he was able to "paint" the mixture on with a brush. If I can find the post I will post a link. However he didn't specify the mixture ratios or which hardner he mixed in (bondo hardner or resin hardner). Any way it looked like a good experiment.
------------- Nothing is impossible!
Date Posted: June 09, 2005 at 10:48 PM
https://www.the12volt.com/installbay/forum_posts.asp?tid=57014&PN=1
Posted By: HottAccord
Date Posted: June 09, 2005 at 11:52 PM
I swear by Rage Gold, it sands like chalk on concrete!!  ------------- Im a fiberglass whore!!
Date Posted: June 10, 2005 at 12:19 AM
Thanx lincolnman! I think I might try that. I saw the post and it looked smooth. It would be killer if I could put it on with a paint gun. I need it smooth cuz Im painting the enclosure.
Posted By: joebiv318
Date Posted: June 10, 2005 at 9:01 AM
Bondo is basically rein mixed with talcum power. Also Bondo hardener is basically the same hardener used in resin, with some talcum power. So to thin out bondo just add resin to your desired thinness and apply w/ a brush. I’m not sure about adding the acetone. I just use the resin. ------------- Owner/ Custom Compact Performance
Treo,Cadence,ARC Audio
Critical Mass/Icon TV
Panasonic,Compustar,Scosche
Posted By: hbk00
Date Posted: June 10, 2005 at 3:47 PM
or try bondo glass work great and sands pretty decent too
------------- go custom or go home!!
Posted By: oonikfraleyoo
Date Posted: June 10, 2005 at 8:00 PM
Why add resin? I can almost see thining the Bondo if you can't get Rage, but I don't understand the resin. Glazing putty is not for smoothing out an enclosure, just to fill tiny pinholes. I also doubt your gonna find anything that will spray on. You need Rage  ------------- Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
Posted By: 1hot944
Date Posted: June 11, 2005 at 12:56 AM
Hey, I've been checking out the posts on the bondo/resin/hardener idea and decided to give it a try. I mixed 1 part Rage gold to 1 part polyester resin. Mixed it up to the consistency of mustard, then when its completely mixed together I added a small amount of the creme hardener that came with the Rage. Mixed well and applied with a paint brush. I layed the door panel out flat on my bench and it went on super smooth and easy, I was also able to get into the tight spots and contours well! And it self levelled!!! I let it set for 3 hrs and went back to check on it. It is completely hardened and looks smooth as glass, very little sanding will be needed. I'll post some pics tomorrow when I get my camera out. ------------- In a world full of copycats, it's great to be an original!
Date Posted: June 15, 2005 at 3:01 AM
personally I like to get the surface smooth and either use Polyester primer filler or for a super expensive paint job use House of Kolors KP21A/B to get it smooth as glass. Both of these products are filling/high build primers to achieve final bild and smoothness.
Posted By: us_test
Date Posted: June 15, 2005 at 12:01 PM
1hot944 - were you able to get the pix? I'm really interested in this (I'll be building new door panels and kick panels very soon).
------------- (1) Kenwood Excelon Head Unit KDC-X589 (24 bit Burr Brown DAC, 3 X 4 volt RCA).
(1) RF Punch 250A2 - running the components.
(1) Hifonics 6.5" Atlas Components (18db crossovers).
Posted By: 1hot944
Date Posted: June 15, 2005 at 10:59 PM
us_test It worked out really well, very little sanding needed. If your door panels or kicks are going to have any tight spots or crevaces you might want to try it!
I'll try to get some more pics up soon, meanwhile you can check progress at: https://www.cardomain.com/ride/557213/9 and https://www.cardomain.com/ride/557213/13 ------------- In a world full of copycats, it's great to be an original!
Posted By: Tangkilla69
Date Posted: June 16, 2005 at 12:32 AM
I like Rage Gold but I love Dolphin Glaze. Its a spray body filler that self levels and doesn't require alot of finishing work. But for those few pin holes just get some 3m Finishing Putty and skim over it.
Posted By: us_test
Date Posted: June 16, 2005 at 7:40 AM
1hot944 - I saw your webpage everything looks good. I'll give this a shot this weekend. I just did some sound deadening on the door panels (I'll keep the stock on for a bit while I get new ones) using WalMart undercoating spray $2.68 per can (I have a detailed post about this). Very recommended product. ------------- (1) Kenwood Excelon Head Unit KDC-X589 (24 bit Burr Brown DAC, 3 X 4 volt RCA).
