sub enclosures?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=62521
Printed Date: May 17, 2024 at 7:49 PM
Topic: sub enclosures?
Posted By: jlord16
Subject: sub enclosures?
Date Posted: September 11, 2005 at 5:51 AM
Alrighty
I have seen pics of systems involving subs where the opposite of a sealed box occurs.  The front of the sub is mounted into an enclosure and the rear is left in the air.  Are these free air subs?  How does the sound/performance comapre to a similar spec. sub in a selaed enclosure.  Is the enclosure im refering to know as the Infinite Baffle setup.  I know lots about sealed enclosures but nuthing about these type.  Why would you use this type of setup besides if u had a free air sub?
the web linkshere has a pic of the type of sub design im talking about
https://www.hzemall.com/our_gallery/installs_tims/accord/trunk.htm
https://www.the12volt.com/installbay/forum_posts.asp?tid=52834&PN=1
Thanks for any imput you have into this topic
Clarion DB36MP
Infinity Kappa Perfect 10"
Respone 800w Mono
ALPINE MRP-F250
*Custom fabrications*
Posted By: stang351w
Date Posted: September 11, 2005 at 8:49 AM
i can answer half of it, it still works the same as a normal sealed box just you don't have the displacement  of the subs inside the box so you could gain a little more air space or make a  box that much smaller for tighter area's, as for sounding different, i don't think it does but i've never really worked with them, i've done one that sounded pretty good, but we never tried the subs the other way to find out if there was any different sound.
Tri County KustomZ
certified installer
Posted By: Poormanq45
Date Posted: September 11, 2005 at 2:59 PM
WHat you're talking about is inverting the sub. SO that the motor structure is outsid ethe box. This makes no difference. Well, it makes a slight difference due to the increased air volume(sub not inside enclosure), which would change the sound a little bit, but not much.
This is not a TRUE infinite baffle(IB) setup. Note that by definition a sealed enclosure could be considered an IB. Normally for an IB the front and rear waves NEVER come in contact with each other. Example in a house: If you mounted a sub in the ceiling with the front firing into the room, and the back left open, this would be considered an IB.
Posted By: auex
Date Posted: September 11, 2005 at 3:09 PM
To add to that: a sealed enclosure where the internal volume is greater than the Vas of the driver.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: Cougar.Modder
Date Posted: September 11, 2005 at 11:18 PM
All in all looks nice. Those Xtant subs looked best too me. No trunk left in the Nissan. Not even a case of beer looked like it would fit. Pitty!!!
Nice though!!!
Alpine 7830 HU-4X100 W McIntosh -2X110 W McIntosh-MB Quart Q's Mid Tweets-4X10" Phoenix Gold Subs-Phoenix Gold EQ215ix-AC Epi-PG Line Driver-Phoenix Gold 1 Farad Cap -Clifford Avantguard 4-2 Ear Plugs
