Air compressor
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=65865
Printed Date: May 15, 2026 at 6:11 PM
Topic: Air compressor
Posted By: menace2sobriety
Subject: Air compressor
Date Posted: November 08, 2005 at 8:53 PM
airbrush. yes you can use automotive paint thru them. a five gallon should work fine for what you are doing. make sure you clean it out well!
Date Posted: November 08, 2005 at 11:01 PM
a cheapo will work for ya! unless you make living doing this. or go down to a hardware sroe they should help you out. or paint shop.
Posted By: mi_what
Date Posted: November 09, 2005 at 6:36 PM
I picked up a complete set from Wal-mart for under a hundred all together. I bought a 2 gallon tank with a 1 1/2 Horsepower compressor set for like 70 bucks (works fine too) and a small HLVP gravity fed gun on sale for like 20-30.
Posted By: mi_what
Date Posted: November 09, 2005 at 6:37 PM
I picked up a complete set from Wal-mart for under a hundred all together. I bought a 2 gallon tank with a 1 1/2 Horsepower compressor set for like 70 bucks (works fine too) and a small HVLP gravity fed gun on sale for like 20-30.
Posted By: phatx96xaccord
Date Posted: November 11, 2005 at 10:35 PM
check out harbor freight for a inexpensive air gun
would u like your chicken original or extra crispy?
Posted By: Dyson
Date Posted: November 15, 2005 at 10:07 AM
a tiny compressor is never going to power a HVLP gun, compressors work of CFM, you need to make sure that there is a higher CFM number on the compressor than the gun. For small panels you could get away with something like a 10 gallon 2hp compressor with a CFM of around 6, and then a conventional gravity or suction feed gun for shooting paint.
Paint guns, if you have the budget, get seperate guns, if you are on a tight budget, at least get a different gun for primers and sealers to colours and clears. Personally i use 4 guns, one for primer, one for colour, one for clear and one for sealer. Primer gun is conventional, colour and clear guns are HVLP. My compressor is 40gallon 3.5 HP with a CFM rating of 15.  Always spend the maximum amount you can afford to. This will pay off with your finishes.
So Check Ebay and see if you can find a compressor and two paint guns in your budget, post them on here, and we can see if they will work with each other!
