theile small, proper air space
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=67271
Printed Date: May 15, 2026 at 5:32 PM
Topic: theile small, proper air space
Posted By: 1990mustang
Subject: theile small, proper air space
Date Posted: November 29, 2005 at 4:56 PM
is there certain calculations you need to get the proper airspace when fiberglassing a box?i was told the calculations include the theile smalles.i have fiberglassed before but not complete sub boxes so any info is greatly apprecited thanx
------------- 1990 mustang rollin on 18 inch lexani firestars,custom stereo,twin turbo 5 litre
Posted By: mi_what
Date Posted: November 29, 2005 at 6:24 PM
Just use the specifications included with your subs; if you're talking about creating the box to the specified airspace, then read the post entitled "Packing Peanut Volume" that should help. I think I understood your question but, if not be sure to say something so we can get you on the right track.
Date Posted: November 30, 2005 at 10:39 AM
ok i read that post and it made some sense but is there no calculations involving the thiele smalles to measure the proper airspace? so i guess you just kinda measure the space your workin with before u start and kinda get a rough estimate for airspace then work with it? i want the whole box fiberglass except the rings and braces. im doing one 12" sub in the drivers side of the trunk in a 2004 acura tsx....any one have ideas or pics?
Posted By: mi_what
Date Posted: November 30, 2005 at 2:52 PM
Nice car. Yeah, first get an idea about the cubic feet needed (for one 12 should be less than a cubic foot), build a box that is at LEAST a cubic foot (you can always take away space easier than adding to it).
Build your box, position your sub rings, and staple down the fleece; then take your measurement. It'll be easier to make adjustments without resin and glass on it.
Date Posted: November 30, 2005 at 5:24 PM
ok thanks for the advice i guess its all trial and error.but your right i can always take space away to get the proper tuning.thanx again
Posted By: jlord16
Date Posted: December 01, 2005 at 12:39 AM
The subs specs should tell you the ideal box volume. If you use the packing peanut method from there onwards to fine tune the box then it will work out good. ------------- Clarion DB36MP
Infinity Kappa Perfect 10"
Respone 800w Mono
ALPINE MRP-F250
*Custom fabrications*
