Resin Clean Up
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=67319
Printed Date: May 15, 2026 at 5:32 PM
Topic: Resin Clean Up
Posted By: cirrusly_fast
Subject: Resin Clean Up
Date Posted: November 30, 2005 at 9:38 AM
Ok so I'm officially an idiot. During my fabrication of my sub enclosures I was doing all the work on my balcony and didn't set down plastic so of course now I have resin, bondo, and paint everywhere. I'm fixing to move out in about 3 weeks and I need to get this stuff up. Is there any kind of solution to get this up without eating thought the cement? I've tried goo gone, and acetone. I've started chiseling but I just wanted to check if there is an easier way.
Cuz I'm Kewl Like That.
System: 1-12" Orion H2, Crossfire VR2000D,Odyssey C2150 battery
Posted By: gus1
Date Posted: November 30, 2005 at 9:51 AM
Nope.... once it's hardened...... have fun.
Gus
Date Posted: November 30, 2005 at 9:54 AM
oh it's been hardened. I did this about 5 months ago.
Posted By: auex
Date Posted: November 30, 2005 at 8:32 PM
Chisel, hammer, new concrete...
I have dried resin on some concrete at my house that has been there for over 7 years.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: stang351w
Date Posted: November 30, 2005 at 8:46 PM
maybe you could rent a good sander...if it's nice and flat where the resin is, it should just sand the resin down then stop befor you go to far...then once it's really thing might be able to remove it easyer...i did it on my work bench once....just i sanded right to the wood..had to cover someone's writing as well :)
Tri County KustomZ
certified installer
Posted By: gus1
Date Posted: November 30, 2005 at 11:52 PM
Could always knock down any obviously high spots, and spring for some spiffy green indoor/outdoor carpet for the affected area :-)
Gus
Posted By: jlord16
Date Posted: December 01, 2005 at 12:42 AM
Resin dosnt stick to concrete very well.  Just get a scraper and try to take it off with that, using a hammer as force if you need to.  The bondo will need to be sanded or chisled off and the paint well its there for a long time now
Clarion DB36MP
Infinity Kappa Perfect 10"
Respone 800w Mono
ALPINE MRP-F250
*Custom fabrications*
Posted By: chrisne77
Date Posted: December 01, 2005 at 10:40 AM
Get a wire brish for a grinder and brush/grind it off.
Date Posted: December 01, 2005 at 3:46 PM
thanks for all the ideas. I went to Home Depot and bought some chisels. I'm getting it clean up, but it's also chipping the concrete. I think I'm gonna end up paying for it but oh well.
Posted By: Alpine Guy
Date Posted: December 02, 2005 at 12:11 PM
use heat to soften the resin up and it should come off alot easier then when its cold.
Posted By: vbel
Date Posted: December 06, 2005 at 2:09 PM
Try to use a heat gun to soften it. I think it should work the best.
Posted By: ajm859830
Date Posted: December 17, 2005 at 12:24 AM
This thread is a bit old but if youre still having trouble use heat on the resin and filler. Once it heats up good enough a good push on it with just about anything will pop it off the concrete. For the paint go to walmart, autozone, etc and buy a can of stuff called aircraft remover & a wire brush. Spray the stuff on there, let it sit, then scrub w/ brush and rub w/ a towel as well even a toothbrush would prolly work.
Date Posted: December 18, 2005 at 5:27 PM
thanks I'll try that when i get a chance in january
Posted By: pentastarturbo
Date Posted: December 19, 2005 at 11:12 PM
wire brush on a drill...       :)
Posted By: captain_zap
Date Posted: December 21, 2005 at 7:05 PM
a demmo hammer might workposted_image
