fleece wrinkles
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=70543
Printed Date: June 06, 2024 at 9:07 AM
Topic: fleece wrinkles
Posted By: darreng
Subject: fleece wrinkles
Date Posted: January 11, 2006 at 1:33 PM
i am building a fb enclosure for 2 12s. i got the frameing how i want it, but in wrapping it part of the fleece has a fold, i cant stretch or manuver to fold out, so i was thinking about cutting it or glassing over it. any advice? I will try to get pictures up soon,
Posted By: 1qwkfox
Date Posted: January 11, 2006 at 1:43 PM
I would try and pull it different ways first .. I've let a few small wrinkles slide and just fixed them with filler before , but its usually not that hard to get them out b4 glass/resin!
Ed
Posted By: youngone
Date Posted: January 11, 2006 at 2:36 PM
i second that.
------------- Want to know some good equipment- JL,Adire Audio,Mcintosh,Brax,Helix,Eclipse,JBL,RE,Dimoand Audio,Zapco, pritty much anything DYhon,Forbidden recommend
On the12volt you give some info and you get in
Posted By: tuscani
Date Posted: January 11, 2006 at 4:14 PM
Acutally, If you have it tight, take and cut the wrinkle out leaving about 1/2" gap in between the 2 pieces, then get yourself a hot glue gun, and stretch the pieces together and glue them so the fold faces into the box. Now just glass over the gap as if it weren't there.
I'd suggest using a much lighter fabric thats even more stretchy, saves you a headache in the long run.
