Fiberglass Piece to Hold an LCD Monitor
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=8169
Printed Date: March 22, 2026 at 6:14 PM
Topic: Fiberglass Piece to Hold an LCD Monitor
Posted By: Robdude30
Subject: Fiberglass Piece to Hold an LCD Monitor
Date Posted: January 15, 2003 at 10:40 AM
I'm making a fiberglass piece to hold an LCD monitor and want to attach it to an existing dash piece(plastic) and then blend the 2 pieces together. 1. Do I just use resin/hardener to "stick" the 2 pieces together and then, when dry, sand the joints smooth? 2. What's the best way to replicate the grain of the existing dash plastic onto the glass? I plan to paint the entire piece, but want it to closely match what I already have. Thanks!
Posted By: audiomechanic
Date Posted: January 15, 2003 at 9:46 PM
it would be easier if i knew the year and car or truck that it is going in... what I always do is take that screen apart.....take the display part out , so you just have the front part of the housing..... once you set there.....you have a couple options on how to proceed....first is you can cut the dash piece so the housing will fit in the dash flush, if thats the case you can just use ca glue to hold it for now. if you want it to sit back a little bit, or it has to, what you can do is cut and shape little pieces of abs plastic to fill the recession gap, CA glue the pieces to the dash piece at the angle that you need and then to the housing of the monitor. then rough it up really good with 40 grit sand paper.....make sure there are some good grooves in it..... then rough up the rest of dash with 80 grit....then wipe the dash really well with wax and grease remover to get rid of all the armor all and crap that builds up on dashes....once the wax and grease remover id dried...whipe it again with a clean dry cloth to get rid of the residue. now there is some people that say body filler or duraglass wont stick to plastic.....it does to a certain degree.....as long as you are not using it to support something (i.e. hold your whole kick panel in place) you are usually good. once it is all glued in place, go through and smooth it in with some good bodyfiller. sand. once it is smoothed pretty good spray the entire dash with a polyester high build primer (i.e. feather fill) and sand with 80 grit, 220 grit....the next step depends on how you wanna finish it . if you wanna paint the whole thing or parts of it ....sand those parst with a 400 grit next.....then wipe with the wax and grease remover then paint... if you wanna texture it first then dye it or paint it .....you can get away with the 220 grit.....the product to use is the green can of 3m rocker panel spray.....its the medium to large texture......set your piece down lower and spray this from about 5 feet away.....this will let the larger "chunks" fall on the piece and the mist will go elsewhere.......give it a good coating and let it dry usually takes about 15-30 minutes to dry...make sure the texture is gonna be close to what you want .....then take 400 grit and (using light pressure) sand the piece again.......this gets all the high spots even, and gives you a good looking texture..........if done right you can match the texture almost exactly, but it will take some practice to get it right ......so play around on some scap abs plastic od wood to get the hang of it.... once the texture is sanded.....wipe it again with the wax and grease remover (just to make sure there is not oils or anything on the piece) then you are ready to dye it .................hope this helped.
Date Posted: January 16, 2003 at 6:13 AM
Very informative reply. Thanks! The monitor is going in an '01 SuperCrew and will sit on top of the dash. Actually it will sit on top of the radio surround trim piece. I invision the new piece as sort of a rounded rectangle with smoothed corners at the bottom going right and left to blend in with the radio trim piece. I will have to remove some material from the top of the radio trim (the portion that the new piece sits over) to allow the monitor to slide in from the bottom. The radio trim will then just snap back in place as it does now. The bond between the old and new piece will have to be solid as it will be holding the weight of the monitor. Thanks again for a great reply!
Posted By: F4Pilot
Date Posted: January 16, 2003 at 9:42 AM
Wow! Thanks for the tutorial audiomechanic What is "ca glue"?
Posted By: 5hift fast
Date Posted: January 16, 2003 at 11:17 AM
ca glue is a glue that is used for many hobby purposes...mainly models and R/C cars. Its kinda like a super glue. I get mine here www.towerhobbies.com
Date Posted: January 16, 2003 at 9:24 PM
its a 2 aprt super glue like 5hift fast said....it has an activator and a glue... it comes in several different types ...we use the loc-tite brand ..it works really well....they have gap filling , black gap filling, general purpose, and many more its kinda expensive, but its worth is
Posted By: F4Pilot
Date Posted: January 17, 2003 at 10:09 AM
Cool thanks. Gap-filling, black gap filling,...Probably could've used many times previous. Does it dry hard, semi-hard, perm flex? ------------- 02 Odyssey / 99 F4
Date Posted: January 17, 2003 at 8:07 PM
it dries hard....you can sand it too!!
Posted By: SnomanF150
Date Posted: January 17, 2003 at 10:26 PM
Just DON'T use it on cuts with the activator... Burns like hell.. Use regular SuperGlue for that..
------------- George
David's Car Stereo
Baton Rouge, LA
Date Posted: January 18, 2003 at 6:07 AM
very true ......but you dont have to tell the rookie in the shop that...it's much more funny to let them learn on their own......haha
Date Posted: January 21, 2003 at 8:21 PM
oh yeah... shhhhhh..
David's Car Stereo
Baton Rouge, LA
Date Posted: January 25, 2003 at 6:14 AM
lol.. i love the little pranks we get to play on the new guys......we just had a new guy doing hood work for a starter (hood pin and tach). we told him on dodges you have to go to the #1 injector and wrap it counter clock wise or it will throw a check engine light ...we even gave him a DEI tech document number .....and he did it !!!! the best part is he has told other people you have to do that !!!! i love not being the new guy!!!!
Posted By: Smooth04
Date Posted: January 31, 2003 at 2:20 PM
What you are thinking of doing is very similar to what I just did in my 2002 Toyota Tundra. I dissasebled the monitor and pulled out the raw screen and remote eye. I then made ABS plastic to trim it in the double DIN opening, painted the abs in a satin black finish, and secured it with JB Weld (works best in these applications in my opinion). The remote eye I hid in the a/c duct of my dash. This is my first time to post in this forum so I hope i can get the pic to show up. Let me know if you have any questions regarding my install.
Date Posted: February 01, 2003 at 7:44 PM
Looks great, Smooth04! Where did you mount your HU? I thought of doing a screen where you put yours, but I would have to move the AC controls and the HU and just don't have the room. I have an F150 and the dash looks very similar to yours. If you can picture this, I plan to make a pod to hold the LCD that mounts to, and blends in with the radio surround, and would sit on top of the trim piece. The location would be similar to mounting above where your screen is and it would be sticking up above the top of the dash a little.
Posted By: Smooth04
Date Posted: February 03, 2003 at 1:18 AM
Thats a cool idea dude, and is probably possible. I made a fiberglass console for my h/u and placed it on the transmission hump. Here is another pic. Forgive the quality of the paint, I was somewhat hurried and didn't have the time to wrap in vinyl.
