pics of the work im doin
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=83551
Printed Date: May 14, 2026 at 10:07 PM
Topic: pics of the work im doin
Posted By: boostedrst
Subject: pics of the work im doin
Date Posted: September 30, 2006 at 3:38 PM
posted_image
posted_image
posted_image
posted_image
posted_image
posted_image
Posted By: g-twizzl
Date Posted: September 30, 2006 at 7:38 PM
Lookin nice so far, what kind of equipment will you be running?
Date Posted: September 30, 2006 at 10:56 PM
box is 2.2cubes tuned to 29hz . heres a pic of the sub i will be running , its a 12'' re sx hybrid made by vitveet on sounddomain .  i will be running the hifonics brutus bxi1206d amp with it . also edead v1se sound deadener .
posted_image
posted_image
Posted By: caraudio904
Date Posted: October 01, 2006 at 3:57 AM
I've made boxes like that before at a shop I use to work at, we called it "The Old 1 - 2" I use to love that design it sounded like 2 12's anyday seemed to be no matter what you put in it. Its gonna really beat your trunk up. Plus it looks like your putting it in a hatch back to even more points!
Southern Stylez
Jacksonville, FL 32218
Posted By: Aruman
Date Posted: October 01, 2006 at 7:10 AM
good so far, what car is it by the way? it looks like an eclipse.
Shaking The Neighborhood
Date Posted: October 01, 2006 at 1:32 PM
yes its a eclipse
Posted By: Aruman
Date Posted: October 02, 2006 at 6:58 AM
cool, nice car.posted_image
Date Posted: October 02, 2006 at 4:56 PM
i got a couple questions . how many layers of mat should i use on the cover ? i have 3 layers of 2 oz mat + the fleece and it seems pretty strong . also do u guys got any ideas on mounting the cover so it doesnt viberate ?
Posted By: Melted Fabric
Date Posted: October 04, 2006 at 11:15 AM
posted_image
posted_image
"hybrid made by vitveet"
I am lost... you had a custom subwoofer made?
You have a link to it?
I have not failed. I've just found 10,000 ways that won't work.
When you do not know what you are doing and what you are doing is the best -- that is inspiration.
Date Posted: October 04, 2006 at 1:04 PM
pretty much custom . it was built by vitveet with some hc soft parts . does anyone have any advise on the questions i asked ?
Posted By: bliz_kid
Date Posted: October 04, 2006 at 9:24 PM
sorry i cant help you with your questin but i have one .... i get the taking the weatherstipping off then putting fleece on then put the stripping back on and glassing
but what do u do then like take it off and toss the stripping and get new stuff ? will the new stuff fit perfectly with the trunk and the cover and still close right?
Date Posted: October 05, 2006 at 12:09 AM
yes the weather stripping got thrown away . no other parts got any fiberglass on it but that . the cover is at the bottom of the weatherstripping lip so it will still close just like stock
Date Posted: October 07, 2006 at 1:20 AM
anyone ?
Posted By: maglin
Date Posted: October 07, 2006 at 10:11 PM
nothing ever fits perfect after customization...
Posted By: Velocity Motors
Date Posted: October 08, 2006 at 12:21 AM
Is the cover that your referring to going to be the actual cover of the enclosure or just another peice that will cover on top on the enclosure for asthetic reasons ? The 3 layers that you have will suffice ( for asthetics ) seeing that you also will need to smooth it out with bondo and this will add more weight to allow the cover to lay over the enclosure as long as this is how you have it designed.
As far as the vibrations thing, I use single side foam tape that's 1/4" thick to act as an anti-vibration material between the cover and the enclosure. You could use Hush Matting but it doesn't conform to the curves as nice as foam tape does.
Posted By: future1
Date Posted: October 08, 2006 at 12:49 AM
hey man looking good! the thickness of the cover should be fine
just some advice for the next one you do soak the fleece in resin then make up a mix of resin and body filler 50/50 use some cream hardner and the liquid hardner and while the original resin you put on the cover is still wet start brushin the bondo/resin mix on. Then apply your chop mat to the underneith of the panel this way you dont have to use a huge amount of bondo to smooth the panel out and it will sand like Bondo too makes for a really quick turn around.
Fred Sherri
Date Posted: October 08, 2006 at 1:30 AM
thanks for the responses . yea the cover is purely cosmetic . it goes over the ported boc and amp box . good idea on the foam tape . also thanks for the tip . i already have it leveled out with the 50/50 bondo resin mix . any tips on mounting it . i was thinking double sided tape or velcro maybe .
Posted By: punkbastard
Date Posted: October 22, 2006 at 10:55 PM
boostedrst wrote:
posted_image
I have a question for you.  In this picture it looks like you have stapled your fleece to your wood frame and yet in later pictures it looks like you have removed just the resin soaked fleece from the trunk leaving the wood frame behind.  Is this in fact what you did?  If so, how did you get the resin to release from the wood given that it was secured to the wood and the soaked with resin, it shouldhave bonded to the wood.  I can see the aluminum foil which wouldn't allow the fleece to adhere to sub box but then did you just pull out the staples?  Also, it doesn't look like you used aluminum foil around the amp rack.
Very nic
Date Posted: October 23, 2006 at 3:00 AM
around the sub box was stapled and the amp rack in back of the seat was stapled . around the sub i just pryed the staples out .while doing that it cracked the resin around the corners off the circle .around the back seat i just cut it where i needed it with a cut off wheel and pulled the excess strip off where it was stapled .the top amp box was also stapled on the mdf piece that holds the plexi was just held on by double sided tape . this way when i pulled out the mold the top piece of mdf over the amp box came off with the mold , i did that so i can drop the plexi straght into the cover . i also pulled the saples out of that just like the sub box . because i didnt put tin foil on that piece ,it bonded to the mdf and is part if the cover . it is also good that way because now theres a baseon the bottom of the cover so that it could be mounted .
Posted By: 05honda
Date Posted: October 30, 2006 at 8:24 AM
How did you make sure that the cover would come off of the top of the box...I knoticed that you stapled them to the box, now how did you remove the cover in one piece with the staples in the box....thanks for the help
Posted By: 1qwkfox
Date Posted: October 30, 2006 at 11:10 AM
I think what he means is once he took the staples out it came off ..also for the top panelif your only using it for looks the fleece should be plenty strong enuff especially after you get your filler on there .
THOUGH is the port facing the rear of the car ? cause that box is REALLY close to the rear wall I dont there is enuff room between panel and port . and if that panel is covering tthe hatch I dont think it will be as loud as you think its gonna be .
JUST my .02 .
Ed
Posted By: glassman326
Date Posted: November 10, 2006 at 3:45 PM
Looks great, excllent work. Keep the pics coming.
I haven't faild I just figured out 10,000 ways not to do it. (sorry had to steal it)
Posted By: maliboom
Date Posted: November 12, 2006 at 9:35 AM
looks great i can't wait to see it done.
