best enclosure for two 15 inch p3.0 Mmats
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=84501
Printed Date: May 14, 2026 at 11:16 PM
Topic: best enclosure for two 15 inch p3.0 Mmats
Posted By: auex
Subject: best enclosure for two 15 inch p3.0 Mmats
Date Posted: October 23, 2006 at 11:53 PM
If you don't have the room for a bandpass then you won't have room for a ported enclosure thus leaving you with sealed as your only option.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: killer sonata
Date Posted: October 24, 2006 at 1:40 PM
Infinite baffle will yiled the best results for low end response. Sealed is your only other option it  sounds like.
Posted By: maliboom
Date Posted: November 16, 2006 at 12:39 AM
You can make a sealed box and add dacron filling to achive the low bass. Dacron tricks the subs into thinking they are in a larger air space.
