Fiberglassing my snowmobile hood
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=84600
Printed Date: May 14, 2026 at 7:40 PM
Topic: Fiberglassing my snowmobile hood
Posted By: denley henstrid
Subject: Fiberglassing my snowmobile hood
Date Posted: October 25, 2006 at 8:17 AM
Last winter I throttle stuck and my snowmobile hit the back of another na broke out a few pieces of the hood. I would like to fiberglass those pieces back in. Can anyone give me a few tips on how to do this?
Thanks a million!
Cheers
Denley
Posted By: realitycheck
Date Posted: October 25, 2006 at 11:04 AM
Pics would help us tell you how to fix it. I would think basically though you could tape a couple layers of aluminum foil on the backside of the hood then lay your glass and resin in there. Overlap the glass a little over the top then grind it down flush once it dries.
Posted By: bellsracer
Date Posted: October 29, 2006 at 2:04 PM
To reinforce the breaks, instead of foiling the backside, you can add a layer of woven FG to give it extra strength.
Posted By: joescarstereo
Date Posted: October 29, 2006 at 10:23 PM
Depending on the size of the break/crack you could also use panel bond just alow 24 hour set up time(panel bond is a 3m product u can get at a harware store
The Car show Kings
Date Posted: October 30, 2006 at 1:42 PM
Bells I was just suggesting the foil so if the hole was too big then the glass would could lay on the foil and just fall through the hole when he layed it down.
