2 kicker cvr12 enclosure opinion
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=93453
Printed Date: May 14, 2026 at 2:15 PM
Topic: 2 kicker cvr12 enclosure opinion
Posted By: flawdaboi407
Subject: 2 kicker cvr12 enclosure opinion
Date Posted: April 29, 2007 at 8:08 PM
I need some dimensions for a box. There 4 ohm subs. I listen to lots of rap. Im running a power acostic 1600 watt amp / 370w rms @ 2ohm and 310rms @ 4 ohm. Thanks.
Posted By: bballguy162006
Date Posted: May 01, 2007 at 2:46 PM
You can find the reccomended dimensions on Kicker's website.  I would suggest a ported or bandpass if you mostly/only listen to rap
Posted By: bellsracer
Date Posted: May 01, 2007 at 10:24 PM
I would forego the bandpass and stick to the ported enclosure... Bandpass boxes are not also called "speaker destroyers" for nothing... Unless they are properly tuned specifically to the subs and only those subs, then any distortions cannot be heard until it is too late (ie the sub is failed and damaged).
The Ported enclosures will give power to the bass notes and easier to set-up and tune properly with less work.
If you haven't bought the subs yet, I would consider going for the loaded dual cvr enclosure from Ciruit City (or wherever available to you) They are precisely tuned, ported and stuffed to give maximum impact for street bass (30-80 Hz).
