6 1/2 inch subwoofer enclosure
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=93829
Printed Date: May 14, 2026 at 10:57 AM
Topic: 6 1/2 inch subwoofer enclosure
Posted By: fatgotti
Subject: 6 1/2 inch subwoofer enclosure
Date Posted: May 11, 2007 at 11:31 PM
Kind of a long story but I have a customer who has a 93 Corvette and wants me to build a enclosure for 6 1/2" subwoofers I have heard it done before but would really like some ideas if anyone has any. I can use 2 or 4 subs but have to be 6 1/2"
Fatgotti    Yeah my name is John and I am FAT!! YEAH BABY
Posted By: speakermakers
Date Posted: May 12, 2007 at 12:33 AM
What type of out put dose this customer expect? What type of music dose he listen to. How much space is he willing to part with? Is he trying to get good sound quality? I do have some sugestions but I need to know what you and your customer are after.
Posted By: fatgotti
Date Posted: May 12, 2007 at 1:21 AM
Mostly jass, already did 2 sets of components just trying to bring a little low end into the vehicle not trying to shake nothing but he has challenged me to this and I cannot turn down a challenge, if you are familiar with a 93 corvette I can take as much space that is left over after he places to small overnight bags are placed in the front of the hatch (directly behind the seats) so I have the back half of the hatch. roughly 12' x 24' x 10'
Date Posted: May 12, 2007 at 2:46 AM
Here is my suggestion
Woofers 2 MCM electronics 11-5585 6.5”
• Specifications::
• Power Capacity: 45W/60W RMS/peak
• Sensitivity: 87dB (W/M)
• Impedance: 8ohm
• Re: 6.6ohm
• Le: 0.44mH
• Frequency response: 40Hz~7KHz
• Fs: 40Hz
• Qts: 0.50
• Qes: 0.66
• Qms: 2.07
• Vas: 29.65 (liters)
• Xmax: 2.4mm
www.mcmelectronics.com
https://www.mcminone.com/product.asp?catalog%5Fname=MCMProducts&category%5Fname=1000211&product%5fid=55%2D1185
These woofers are very inexpensive but don’t under estimate them! They don’t cost much because they are not marketed for the car audio industry and come strait from Taiwan to this warehouse. They are 8 ohms each. Wire them in parallel for a single 4 ohm load.
The box
posted_image
Isobaric double tuned parallel band pass
Chamber one (VB1)is 1.1 cu.ft
With a 2” port 5.7” long tuned to 32.64hz
Chamber two (VB2)is .442 cu.ft
With a 3” port 9.3” long tuned to 60.38hz
This box will have fast bass and will also play deep. You will get about the same amount of output as a single healthy 8” in a vented enclosure
posted_image
The red line is the way that the box will sound outside the car and the orange line represents roughly how it will sound in the car.
Make sure to give it 150 watts total at 4 ohms and if the amp has a subsonic filter set it to 30hz that will give you the ability to play even louder.
This box is big at 1.5 cubic feet, but good bass takes up space.
Don’t stuff the box, and don’t worry about the tuning frequencies. Just build it to the volume that I recommend along with the exact port lengths and it will sound great.
The sub in VB1 is wired out of phase so that they both move in the same direction.
Posted By: fatgotti
Date Posted: May 12, 2007 at 8:00 AM
     I have never built a Isobaric double tuned parallel band pass enclosure before so if I wire sub A's + to sub B's - and vise versa then parrelel to amp I will get a 4 ohm load?  Thanks for help I am really excited now I get tired of the same ole boxes over and over. this is not of the norm and I thank you for all of your help.
Date Posted: May 12, 2007 at 9:11 PM
posted_image
Posted By: fatgotti
Date Posted: May 13, 2007 at 10:00 PM
Thanks for your help I used different subs by customer request but it turned out great I am not sure if it impressed him or me more.  Once again this forum has saved me thank you...
Date Posted: May 19, 2007 at 12:05 AM
That’s really good to hear!
Posted By: 01trublugt
Date Posted: August 01, 2007 at 10:44 AM
Toying with this idea just to give me something to do.
Speakermakers: does the volume for the box you listed above take into account the speaker and port displacement or will I have to add thoes values in to get the proper internal volume.
For example you listed VB1 as being 1.1cu.ft. ; A box 12.15x12.5x12.5 would be about .001% off. WOuld that be appropriate or do I have to add speaker and port displacement to the 1.1cu.ft.?
