led lights in headlights and taillights
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=104009
Printed Date: May 05, 2026 at 2:50 PM
Topic: led lights in headlights and taillights
Posted By: mtpg15
Subject: led lights in headlights and taillights
Date Posted: April 15, 2008 at 3:23 PM
Hey everyone. I am having a problem with the double flash rate on my newly installed LED turn signals. At first I had two 3 ohm load equalizers on the front turn signal lights. (It said you should only need one 3 ohm equalizer for each side of the car) Turn signals worked fine when the car was in "on" position without the motor running but once I started the car the turn signals flashed at double rate again. So I then ordered two more 3 ohm load equalizers for the rear turn signal lights. Still getting the double flash rate. I then ordered four 6 ohm load equalizers thinking this would fix the problem for good but I was still getting the double flash rate. Can anybody help? It is greatly appreciated as these lights look so good but the double flash rate is getting very irritating.
Thanks,
Matt
Posted By: plumber_ken
Date Posted: May 03, 2008 at 10:26 PM
Depending on whether your vehice has a signal relay...
mine doesnt of coarse :(  ( 2006 dodge caravan)
they do have "led Friendly" relays...jus replace your factory relay ..with the led friendly one and your problem should be solved..
Posted By: KPierson
Date Posted: May 04, 2008 at 10:43 AM
What kind of vehicle do you have?  What is the resistance of each turn signal bulb?  Instead of just ordering random values it may be beneficial to measure the stock bulbs and order that resistance.
3 and 6 ohms seem very small for a turn signal bulb but it will change from car to car.
Kevin Pierson
Posted By: mtpg15
Date Posted: May 04, 2008 at 12:04 PM
I have a 2006 Chevy Impala LS.
I purchased the bulbs from here: https://autolumination.com/3157_3156.htm
They are the 27 LED SMT bulbs.
Matt
Posted By: KPierson
Date Posted: May 04, 2008 at 1:52 PM
You need to know the resistance of the STOCK turn signals, not the aftermarket ones.
Kevin Pierson
Posted By: mtpg15
Date Posted: May 04, 2008 at 2:16 PM
OK, and I'll need a voltage meter for that?
Matt
Posted By: ryan@tcp
Date Posted: June 04, 2008 at 9:04 AM
yes, you'll need a multimeter to test the resistance. If you have never used one before I sugest you read up on multimeter use (a quick Google search will have all kinds of great info) before you start.
Good luck.
