strobe lights?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=112712
Printed Date: May 12, 2026 at 2:04 PM
Topic: strobe lights?
Posted By: carguy411
Subject: strobe lights?
Date Posted: March 27, 2009 at 1:10 AM
ive done quite a few set of strobes in headlights and taillights. the only problem i run into and which a real time killer is when you drill the 1" hole how does everyone clean out the houseing of all the plastic shavings. it takes me forever and sometimes still have particles leftover. i tried everything. using a shop vac while drilling ,, shopvac and air compressor.
any hits u might have
thanks
Posted By: davo12662
Date Posted: March 28, 2009 at 4:57 AM
is there any way to try and spilt the headlight open? iknow most ef em are sealed pretty good from the factory but maybe just a diffterent was to look at it.. what year/model vehicle?
Date Posted: March 28, 2009 at 9:58 AM
yeah that is a pain then u have the chance of it not sealing right. its for all veh. i do few and its just annoying wasting so much time trying to clean out the lense. thought someone had a trick in doing it. i actually drill and vacume at the same time. kinda works but still leves pices in there
Posted By: firstrax
Date Posted: March 29, 2009 at 8:07 PM
I used a unibit. Push hard and turn at a very low rpm.
The idea was to open the hole by shaving off one long continuos curly. Sometimes turning by hand while holding the curly with the other.
Date Posted: March 30, 2009 at 9:16 AM
yeah maybe thats better i was usin ga hole saw.
anyone else have an idea.
thanks
Posted By: kris05vvti
Date Posted: March 30, 2009 at 2:33 PM
posted_image
thats exactly how i do it =]
Posted By: grgvalliere
Date Posted: September 19, 2009 at 3:19 AM
I would just take a piece of duct tape and put it over the drill spot.
Posted By: i am an idiot
Date Posted: September 19, 2009 at 5:16 AM
I would attach a 1/2 inch flexible hose to the vacuum cleaner, turn the headlight to get all the trash in one area and navigate the hose to that corner.
Posted By: blackrosetiger2
Date Posted: November 26, 2009 at 8:38 PM
Take your shop vac and gorilla tape a 3/4" piece of clear tube to it. it should pull most of it out. I would the rinse out the headlight with a hose afterwards and allow to dry fully before installing the strobe and resealing it.
You only dont know what you don't ask about
Sacred Ground C.C.
Posted By: jimmy poulin
Date Posted: November 28, 2009 at 6:50 AM
Hi!
This is the way i do it. I use my soldering station with a fine blade to cut lexan, acrilyc, PVC or other plastic. It make dustfree and flakefree opening. But you will need VENTILATING the area where you working A LOT!!! And don't forget to cut upside down for dripping melt plastic don't fell in and also the part you're cutting.
Good luck!
Posted By: mastermindz
Date Posted: January 12, 2010 at 4:43 PM
I drilled my headlights to put strobes and just used a small piece of wire hanger to get the larger pieces out and then shook the little pieces out, guess it depends on the headlight huh
Mastermindz
