dancing lights
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=135398
Printed Date: April 25, 2026 at 7:59 AM
Topic: dancing lights
Posted By: 04nata
Subject: dancing lights
Date Posted: November 27, 2013 at 10:06 PM
Back in the day we used to buy these lights from Radio Shack, put them in the marker lights or headlights and just turn them on while parked just because. They randomly flash as they warm up and created a flickering/dancing effect.
So I wanted to get them now (20 years later) and use them, just because nobody else does, They are discontinued at Radio Shack and I cannot find them anywhere. I know they have flashing LED's which will work, but what would be the easiest way to make them randomly flash so they are not all just blinking on and off at the same time? Like a list of parts and schematic possibly?  ------------- 2004 Hyundai Sonata
Kenwood KDC-X599 HU
2-Sundown X-18D4
2-SQ Q4500.1
2-SQ Q90.4
1-Massive DBX4
8-Niche 5.25 mids
8-Niche Tweeters
4-Skar 8" mid-bass
OhioGen 220a alt
OhioGen 350a alt
156.0
Posted By: powerslave
Date Posted: December 03, 2013 at 11:06 AM
Give this a shot, I have done it with similar devices:
+12 to LED, LED to one of those Bulbs, Bulb to ground.
Basically, you are using one of those bulbs as your ground path, and once it heats up, will remove ground each time it blinks off.
Posted By: 04nata
Date Posted: December 08, 2013 at 12:49 PM
Cant do that, I have NONE of these bulbs available
Kenwood KDC-X599 HU
2-Sundown X-18D4
2-SQ Q4500.1
2-SQ Q90.4
1-Massive DBX4
8-Niche 5.25 mids
8-Niche Tweeters
4-Skar 8" mid-bass
OhioGen 220a alt
OhioGen 350a alt
156.0
Date Posted: December 11, 2013 at 11:03 PM
Then you have to build a random on/off circuit.
The 4026 IC Timer Chip combines a counter and a seven segment LED driver. The seven-segment outputs plus a divide-by-ten output will drive eight LEDs. While the flashing will not be strictly random, when the lights are properly arranged, they won't have a discernable pattern. This circuit needs only the 4026, a 555 timer, LEDs and a few passive components to make it complete.
Posted By: 04nata
Date Posted: December 12, 2013 at 4:03 AM
Sweet, thank you.
I recognize the resistors 10k and 47k but whats the 1uF component?
And also I assume that I need 9v LED's or will it work the same with 12volt source and 12 volt LED's? ------------- 2004 Hyundai Sonata
Kenwood KDC-X599 HU
2-Sundown X-18D4
2-SQ Q4500.1
2-SQ Q90.4
1-Massive DBX4
8-Niche 5.25 mids
8-Niche Tweeters
4-Skar 8" mid-bass
OhioGen 220a alt
OhioGen 350a alt
156.0
Date Posted: December 14, 2013 at 6:28 PM
1uF is a capacitor.
Not sure on the input voltage at 12V. If you had to, your best bet is a simple voltage regulator circuit using an LM317, 3 terminal voltage regulator and two resistors. They may still have these at Radio Shack or at least they can order one. Shouldn't be too hard to find info about building a simple voltage regulator online.
LEDs can run on variable voltages.
Posted By: oldspark
Date Posted: December 15, 2013 at 2:02 AM
Note that the circuit shown does not include buffers or resistors for the LEDs.
The CD4026 is only guaranteed to source or sink ~5mA at ~12V though 20mA is possible.
And I see nothing to indicate current limiting outputs, hence you need to fit resistors etc unless LED current is (maybe?) 20mA or less.
(FYI - the 4026 is a decade counter to 7-segment LED decoder, hence not "random" but 10 different patterns.)
PS - the 4026 tolerates 3V - 18V so it's only the 555 & LEDs you need worry about.
And add at least a decoupling cap for the 555 (0.1uf?) for "correct" operation, tho insufficient dc decoupling/filtering may mean truly random operation...?!)
Date Posted: December 16, 2013 at 12:48 AM
FYI, I have, in the message detail:
The 4026 IC Timer Chip combines a counter and a seven segment LED driver. The seven-segment outputs plus a divide-by-ten output will drive eight LEDs. While the flashing will not be strictly random, when the lights are properly arranged, they won't have a discernible pattern.
Thanks for repeating what I already had...
Posted By: oldspark
Date Posted: December 16, 2013 at 1:15 AM
Ah cool, so you can just connect the LEDs without resistor to the 4026 as per your detail.
Oh hang on, are you merely referring to my trivial parenthesised and smallest paragraph, and not the other two key paragraphs...?
If not, I severely apologise for adding info that I thought would prevent circuit failure.
Date Posted: December 17, 2013 at 9:45 PM
I was only referring to what was in Parenthesis, as I did say that info from the beginning.
Posted By: oldspark
Date Posted: December 18, 2013 at 1:03 AM
So now there are 4 replies with no value add.
Or maybe I fail to see what your point was?
