Daytime Running Lights DRL on w/Engine?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=138493
Printed Date: May 03, 2024 at 5:16 AM
Topic: Daytime Running Lights DRL on w/Engine?
Posted By: chassis
Subject: Daytime Running Lights DRL on w/Engine?
Date Posted: February 16, 2015 at 10:56 AM
Good day.
I would like to know how to connect DRL lights properly.most guys here in my country link them up with the parks.but the purpose for them is to come on with the engine, and while engine is on ,they should go off when you switch the lights on.is there any relays involve here?
Thanks in advance
------------- Do it once,do it right - This means no short cuts. You never get paid twice for having to do the job twice because it wasn't done right the first time.
Posted By: oldspark
Date Posted: February 17, 2015 at 1:35 AM
If engine means running, try using the alternator's charge light circuit [search for UIBI (battery isolators; electric fuel pump control, etc)]. Otherwise use IGN +12V
To disable with lights on, the (UIBI) relay's GND (85) could be to a headlight's switched +12V via a diode (line to headlight).
Posted By: chassis
Date Posted: February 18, 2015 at 9:36 AM
Thanks a lot
